Brazil Cases No Tacho Holes !!!
Headcoats
#1 Post by Headcoats » Thu Feb 10, 2011 3:11 pm
I have some really good cases for my LC build but the only problem i can see is that as i want to run a mechanical tacho with cable etc to fit my old LC clocks.
Has anyone machined the cases to accept the gears for the mechanical drive ?
Bare
#2 Post by Bare » Thu Feb 10, 2011 10:55 pm
Why... not just make the Electric Tach fit into the LC Clocks container ?
You need only the mechanical bits inserted into an old and likely dead LC tach housing.
No dicking with the engine cases :-)
aaronmvrider
#3 Post by aaronmvrider » Fri Feb 11, 2011 1:31 am
quite possible his bike / harness doesnt have the wiring for a digital tacho.... unless you are running a zeeltronic ??
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
Headcoats
#4 Post by Headcoats » Fri Feb 11, 2011 3:07 am
It has been so hard to find a good set of cases this is the compromise i'm afraid.
It's all there but blanked off :smt010
No zeeltronic and no digi tacho i'm afraid
Billy
#5 Post by Billy » Sun Feb 13, 2011 1:26 pm
When you say "it's all there but blanked off", do you mean it looks like normal but the hole is plugged by something? I had a case like that, there was a rubber plop in the hole, (I think the plop was white but may remember wrong) I just pried it out and installed the tacho mechanics. :smt001
Headcoats
Re: Brazil Cases No Tacho Holes !!!
#6 Post by Headcoats » Sat May 26, 2018 4:05 pm
Back on this thread again
2011 was the last post , where has that time gone !
You guessed it, I still haven't done anything LOL
