ignition settings
cbn70
ignition settings
#1 Post by cbn70 » Mon Dec 13, 2010 12:13 pm
Hi,
What are people running for ignition advance. i know on my banshee I have it set at 4 degrees advanced. How would this work on my rz350.
wicked motorsports
Re: ignition settings
#2 Post by wicked motorsports » Mon Dec 13, 2010 2:49 pm
cbn70 wrote:Hi,
that's perfect! Just follow your banshee settings for +4. I wouldn't go further than that unless you ran more Octane over 100 I did so on both and the RZ's I own and the ones I've build. Works Great!. you'll notice alone the throttle response and if the jetting is a tad fat you'll see it clean that up down low.
Wicked Motorsports Inc.
10552 Stanford Ave.
Garden Grove, CA 92840
The United States
http://www.wickedatv.com" onclick="window.open(this.href);return false;
1-714-530-2215 fax 1-714-530-2217
E-mail: roger@wickedatv.com
cbn70
#3 Post by cbn70 » Mon Dec 13, 2010 3:48 pm
Glad to hear that. Want to get it ready for the summer, now I just need to order one and get it installed. Guess I can put on the shaved flywheel as well. Bigger carbs and I am ready to go. I know it made a big difference on my shee. Was hoping for the same on my rz
wicked motorsports
#4 Post by wicked motorsports » Mon Dec 13, 2010 4:49 pm
it will. Don't waste the time and money on the fly wheel. Unless you weigh 110-140Ib it's not a good idea. On the banshee or the RZ. You need that extra rotating mass to keep the low end. We've stop doing fly wheel mods long ago sense we realized what it didn't help just hurt it. As well you'll notice the same problem when guy's use Button style fly wheel ignitions Example PVL's the bike sounds mean sitting there but it does take away power under a load. The Larger Carbs will benefit you as well. I just recommend if you do that make sure you at least have Pipes, Ported and compression. reeds will also be a gain. all this and carbs will fit the RZ Nicely. If not you'll be some what over carburetaing something that can't flow it. I'm also using a 33mm carbs and up for Example. If you plan on using 28 then you'll be fine with out any port work. Just trying to give you ideas to maintain the low end.
10552 Stanford Ave.
The United States
cbn70
#5 Post by cbn70 » Mon Dec 13, 2010 9:07 pm
Yes just using 28 pwk`s. Already have a 2 into 1 intake setup, toomey pipes and boysend reeds, and head shaved .015. Going to do the advance. Think it will make for a nice little setup. Not the biggest or fastest, but will be a lot of fun.
petros67
#6 Post by petros67 » Tue Dec 14, 2010 1:53 am
wicked motorsports wrote:
cbn70 wrote:Hi,
Roger , would you say that + 4 degrees advance would be ok for my 421cc banshee ??? I'm waiting for the zeel to arrive.
What settings should I go for ??? whats your opinion as you have huge experience with these stroker engines.
Petros
wicked motorsports
#7 Post by wicked motorsports » Tue Dec 14, 2010 6:24 pm
cbn70 wrote:Yes just using 28 pwk`s. Already have a 2 into 1 intake setup, toomey pipes and boysend reeds, and head shaved .015. Going to do the advance. Think it will make for a nice little setup. Not the biggest or fastest, but will be a lot of fun.
You'll have with it. Sounds like a nice set up. :smt023
10552 Stanford Ave.
The United States
wicked motorsports
#8 Post by wicked motorsports » Tue Dec 14, 2010 6:26 pm
cbn70 wrote:Hi,
Petros
Hi Petros! do you know what Compression you have on that Cub? Also what fuel octane? as well Pistons?
10552 Stanford Ave.
The United States
cbn70
#9 Post by cbn70 » Tue Dec 14, 2010 6:56 pm
not sure, might open up the engine and port the cases to match the cylinders. Have done this on banshees and works well. I have to put in a new set of rings so might just bite the bullet and pull the motor. The guy who started LRD performace in Oregon actually says porting the cases is good for 1-2 horsepower on an engine.
petros67
#10 Post by petros67 » Wed Dec 15, 2010 1:37 am
Roger ,
Engine has not fired up yet ...... , so do not know compresion ,
Fuel will be 100 octaine unleaded as going for a road bike ,
68mm Wiseco forged pistons.
Petros
wicked motorsports
#11 Post by wicked motorsports » Wed Dec 15, 2010 7:54 pm
petros67 wrote:Roger ,
Petros
How About Domes? what cc are they?
10552 Stanford Ave.
The United States
KennyBarroz
#12 Post by KennyBarroz » Thu Dec 16, 2010 8:36 pm
If i would get 0,9 in squish, would +4 in timing be good still? :smt017
RD350 F2 -87: SETUP :
Stock 65mm barrels, TSS YPVS kit, 0,9squish, Vforce3 reeds, stock intake for Vforce3 reeds, 28mm PWK custom made for oilpump and vacuum line, jets 120/40, modified airbox, Zeeltronic PCDI-10V - Custom curve
slinger
#13 Post by slinger » Thu Dec 16, 2010 9:09 pm
KennyBarroz wrote:If i would get 0,9 in squish, would +4 in timing be good still? :smt017
It depends on what you want or are looking for.
Your still only going to be seeing about 15* at peak power, these engines if tuned correctly need a lot more than that.
Unleaded fuel needs to be run rich with loads of advance to get the heat into the pipe to make them work at the temp they where designed to run at.
There are so many things that can alter what ignition curve is best suited for a given tune, like the angle of the rear cone plays a major factor to the ignition curve. Just saying +4* is ace is wrong IMO better than standard granted, but I guess it all depends on what you want.
And before the shit stirrers come out, it's by no means a dig at Roger as +4 is better than nothing.
Glyn
cbn70
#14 Post by cbn70 » Thu Dec 16, 2010 9:29 pm
I hate it when the shit stirrers come out!!!! There always is a know it all, who thinks his opinion is king
cbn70
#15 Post by cbn70 » Thu Dec 16, 2010 9:41 pm
Wish there was a better way to see what works when it comes to ignition setting other than on a dyno, with someone who know what they are doing
