straight cut drive gears
I don't know of any straight cut oil pump gears. These gear sets were for banshees and race bikes where the oil pump would not be required or wanted. However, that doesn't stop you from having one made. Since the drive gear is bigger, then that would make the straight cut oil pump gear smaller. this would cause more oil to pump per rev of the engine. Some readjustment would be required.
Fuel Injected RZ350
smurph wrote:I don't know of any straight cut oil pump gears. These gear sets were for banshees and race bikes where the oil pump would not be required or wanted. However, that doesn't stop you from having one made. Since the drive gear is bigger, then that would make the straight cut oil pump gear smaller. this would cause more oil to pump per rev of the engine. Some readjustment would be required.
those gears came from a TZ...
FJ, tomorrow I'll count...
but it gave me 2,538
I'll check again if the driven (basket) is the same size as stock.
RE-CHECKED
Edit:
DAAAAAAAAUUUUUUUUUUMN, I'M SO HAPPY RIGHT NOW!
The drive is 26... the driven is 72...
72/26 = 2,7692307692307692307692307692308
then 6 gear ratio is 0.889, my final chain ratio is 2.294117 with 190/55 ZR17 at 10.000rpm hummmmmm
213.9kph with staright tooth powah!
"...It's just like traveling on a plane, but, without that horrible meal... and with the window opened..."
(RD350 87')
pics updated
the little one that I had on my "garbage"....
(RD350 87')
We had a racing class (RD cup between 86-89 I guess) here on Brazil that were only RDs racing, and no "engine" mods was allowed...but this was placed inside the engine and if makes more power and can't be seen, it's great... they're used to change the 1YH stupid with 2. squish for the 31k head too...FJ55 wrote:I'm also curious as to what TZ they came out of. I done minimal research, but have been unable to find any TZ reference to that ratio primary.
Nath, until now it's straight plug 'n play I'll post some pics from the engine buildup...nath wrote:hellmanns, are you saying these came from a TZ and will fit the RZ basket or some modification is required ?
(RD350 87')
All TZ I know have dry clutches. This one is wet clutch. From the morphology (layout) of the TZ350 engine there is no oil pump, but a water pump close to the oil pump position.
I think that these gears are specialy made for RZ350 to be hidden under the OEM clutch cover.
I said hidden because the class was for non modified RZ350
geosot wrote:All TZ I know have dry clutches. This one is wet clutch. From the morphology (layout) of the TZ350 engine there is no oil pump, but a water pump close to the oil pump position.
Geosot,
the TZ primary it's the little driver gear on the same pic, the guy who gave me this gear kit lost the driven part... :(
(RD350 87')
Re:
I put in ebay a couple of straight cut primaries that run on roller bearings and with oil pump gear.smurph wrote:I don't know of any straight cut oil pump gears. These gear sets were for banshees and race bikes where the oil pump would not be required or wanted. However, that doesn't stop you from having one made. Since the drive gear is bigger, then that would make the straight cut oil pump gear smaller. this would cause more oil to pump per rev of the engine. Some readjustment would be required.
Re: straight cut drive gears
you can buy it:
http://www.ebay.com/itm/251269901845?it ... m=&vxp=mtr" onclick="window.open(this.href);return false;
e:
http://www.ebay.com/itm/RZ350-RD350YPVS ... 3a80067bd3" onclick="window.open(this.href);return false;
e:
RDR 350/93 modified(a lot) to +4 crank, 68mm piston, yz125 reed , TZ 96 seat with modified tank/frame, RGV front fairing/light, gixxer brakes, TM34 PJ, 17 weels, lightened flyweel, koso RX2n tachometer, pod air filters, 600 f4 rear shock
Yamaha XT 660
Yamaha XT 660
joel74 wrote:you can buy it:
e:
Bem vindo, Joel, um abraço.
Welcome, Joel, a hug for you.
thanks man.Ripp wrote:joel74 wrote:you can buy it:
e:
Yamaha XT 660
Yamaha XT 660
