RZ 350 crank
p51mustang
RZ 350 crank
#1 Post by p51mustang » Sun Jan 20, 2019 11:01 am
Anyone no if you can use a TZ 350 crank in a RZ 350
1978 RD 400
1979 Daytona
bitzz
Re: RZ 350 crank
#2 Post by bitzz » Sun Jan 20, 2019 3:47 pm
The RZ crank is located in the case by the outer bearings.
The TZ crank is located by the inner bearings and lab seal.
The key to locate the ignition on the taper is off by 90 degrees.
What is it you're trying to gain? A TZ crank weighs more than a RZ crank.
OldTZracer
Re: RZ 350 crank
#3 Post by OldTZracer » Mon Jan 21, 2019 2:29 am
The key is in the right spot if you use the TZ ignition as well...
The crank will "fit" but is narrower centre-to-centre, so you can't use the TZ outer rollers and a shim is required behind the locating outer mainbearing to centre it. Even then, the flywheels may still rub.
Bitzz is right - the RZ crank is a stronger design but just what do you have in mind?
Bare
Re: RZ 350 crank
#4 Post by Bare » Wed Jan 23, 2019 9:51 pm
Weighs more cuz it's better balanced.
RZ ones are poorly balanced in 350 usage.
Despite this the RZ crank is more durable/stronger having wider Bottom rod bearings
The narrower width is a bit of a nuisance as well.
Sell it on to some Twit and use the coin to buy an RZ one?
RZtuner
Re: RZ 350 crank
#5 Post by RZtuner » Thu Jan 24, 2019 2:02 pm
The best cranks on the market are Vito's high performance race cranks, these are what I use in my race bikes.
https://www.amazon.com/Yamaha-Banshee-c ... crankshaft
High quality 8 ball Japanese Koyo bearings
peek coated cages
keyed center crank instead of pinned, trued and welded
Rods are shot peened and polished (really nice touch!)
Fits all Banshee and RZ350's
These are much better quality than OEM and great value. Measured 0.000 run-out on my dial gauge and I've never had a problem with them.
AMA No.1plate holder x2
