FUEL
Re: FUEL
You don't need to go to a marina for non-ethanol. Go to puregas.org to find ethanol free in your area. They usually post octane ratings too.
Re: FUEL
The nearest station listed on puregas is 167 miles from me.
The addiction:
85 RZ350 Bought it new!
76 GT750 Project
73 H2 Project
75 GT185 Project
03 MG V11 LeMans
90 CB1 It runs
12 650GS Runner
87 K75C Should run forever
02 1150GS Used to work
76 GT750 Project
73 H2 Project
75 GT185 Project
03 MG V11 LeMans
90 CB1 It runs
12 650GS Runner
Re: FUEL
What octane does the owners manual call for ? I have one gas station close to me that sells 90 octane pure gas( ethanol free) would this work ok? I have stock compression and timing.
84 RZ350 Toomey
2003 FZ1 Yellow/Black
BULTACO ASTRO
Champion framed Kawasaki F81m
ZUK A-100 w/ FACTORY HOP UP
BULTACO ASTRO
Re: FUEL
NON- Ethanol/Methanol 90 or 91 is PERFECT.
pure-gas.org is a good start but not exactly an all-knowing site.
Many of the fuel stations listed at pure-gas.org are actually lawnmower, auto parts stores, and bike shops that sell 1 qt, 1 gallon and 5 gallon containers of VP or other brand-name non-alcohol fuel in a can. Not pumping stations. In New Hampshire, 15 of the 44 listed are either airports, marina's or Lawn-tractor or bike shops. While this is excellent gas, the price of small quantity (1 qt) canned VP is well over $40/gallon! $87.99 for 5 gallons of VP 4-cycle at the local auto-parts store or bike shop is average around here.
There are several "normal" gas stations on there as well, but the list is pretty sparse.
The closest pumping station listed to me is an airport. The next closest is 40 miles away. There are at least two unlisted pumping stations closer to me that sell race gas from the pump for a more reasonable $9 to $12 per gallon.
Also, be aware that Marinas and airports are not likely to allow you to pull up on your bike and fill your tank. You generally need to bring your 5-gallon jugs and fill. I think it's a tax issue.
Re: FUEL
Yes our pure gas is a actual pumping station , they have a separate tank just for this.. in farm country.
84 RZ350 Toomey
BULTACO ASTRO
BULTACO ASTRO
- Evans Ward
Re: FUEL
All my local pure gas stations are actual gas stations, convenience stores with pumps, etc. I take two 5 gallon jugs with me for fill ups and use as needed at home between my bikes and lawn mowers (all 2 cycle BTW) It’s time for another puregas trip already.
Re: FUEL
most all of the pure gas stations around me , not that close are 90 octane.. there is one about a hour away that is 94. what octane r u using Evans ?
84 RZ350 Toomey
BULTACO ASTRO
BULTACO ASTRO
- Evans Ward
Re: FUEL
^ 92 octane
Re: FUEL
The original US owner manual doesn't have a minimum octane noted anywhere. I expect that an octane rating of 90 or greater is fine as that was a common minimum for several 2-stroke MX bikes I owned in the 80's. MX bikes are generally producing more HP per cc and make a good yard-stick in this case.
Re: FUEL
IMO Octane ratings have been obusificated almost into meaninglessness.
My pore Superbeetle (bought new) ran for decades on Cheap gas, it had a 6;1 comp ratio IIRC
Then "new" octane ratings appeared and I had to use either 89 or 92 to prevent misfires.
Ignore the rating number and use what gives the desired result.
Re: FUEL
It could also be your jetting or it could be the lack of lead. Lot's of people complain about unleaded fuels causing problems, even with higher octane ratings, in classic cars and motorcycles.Bare wrote: ↑Sun Dec 30, 2018 10:36 pm IMO Octane ratings have been obusificated almost into meaninglessness.
Fuel with alcohol content is also known as "oxygenated" fuel. It makes your jetting lean and lean jetting can cause knock.
