Transmission oil
Transmission oil
Quick question , manuals and engine case says 1500cc in tranny case on rz350. But in a 48oz and it was way over full?.?
84 RZ350 Toomey
2003 FZ1 Yellow/Black
BULTACO ASTRO
Champion framed Kawasaki F81m
ZUK A-100 w/ FACTORY HOP UP
BULTACO ASTRO
Re: Transmission oil
1500 cc is what it will take when it is completely empty like after a dissambly/rebuild. When filling after a fluid change, put in a quart/liter then add to full. And don't forget to check the level after a warmup.
So on a oil change there is still almost 16 oz left in the motor.
84 RZ350 Toomey
BULTACO ASTRO
BULTACO ASTRO
How exactly do you measure your oil level?
Just sit the stick in the case. Did not thread it in.. put 11/2 quarts in it and took out almost 1/2 quart to get the level correct on the stick
84 RZ350 Toomey
BULTACO ASTRO
BULTACO ASTRO
Sounds like you are checking correctly. Mine usually takes a quart bottle plus about 1/4 to 1/3 of a second bottle.
- T.RexRacing
Are you measuring while on the sidestand? If so there's your problem.
Salvador Dali
Salvador Dali
I think his side stand is still on the left side of the bike........T.RexRacing wrote: ↑Mon Dec 17, 2018 12:24 pm Are you measuring while on the sidestand? If so there's your problem.
if you just pour it in and check it will seem over full. Start it up and let it circulate, then check.
I don't even bother checking anymore. I get it hot, drain well, pour in 1.5L and go. +/- 50ml out of 1500 is not going to make much of a difference.
- T.RexRacing
brrrappp wrote: ↑Mon Dec 17, 2018 7:27 pmI think his side stand is still on the left side of the bike........T.RexRacing wrote: ↑Mon Dec 17, 2018 12:24 pm Are you measuring while on the sidestand? If so there's your problem.
yeah brain cramp. Nevermind.
Salvador Dali
Salvador Dali
