CARB RZ350 EXTRA PART UGH
hotshoe93
#1 Post by hotshoe93 » Mon Dec 03, 2018 12:43 pm
I JUST REBUILT THRE CARBS ON THE RZ350 AND AFTER ALL ASSEMBLED , THERE WAS A BUSHING LEFT LAYING ON THE BENCH. I TOOK THEM APART AGAIN AND CAN NOT FIND A PLACE FOR IT ..THE PIN THAT IS ON BOTH CARBS THAT SECURE THE SLIDE HAS THE WASHER AND BUSHING ON BOTH SIDES OF IT. JUST DO NOT KNOW WHERE THIS ONE WOULD GOE.. PARTS BOOK DOES NOT SHOW ANOTHER BUSHING. THE BUSHING IS 14MM OD ,8MM ID AND 4.8MM THICK. IT IS THE RIGHT SIZE ID FOR THE SLIDE PIN TO GO THROUGH BUT THERE IS NO PLACE TO PUT IT.
84 RZ350 Toomey
2003 FZ1 Yellow/Black
BULTACO ASTRO
Champion framed Kawasaki F81m
ZUK A-100 w/ FACTORY HOP UP
:smt026
hotshoe93
Re: CARB RZ350 EXTRA PART UGH
#2 Post by hotshoe93 » Mon Dec 03, 2018 12:48 pm
another quick spec. the bushing is white plastic just like the one on the pins the activate the slides ??? Thx
84 RZ350 Toomey
BULTACO ASTRO
:smt026
Evans Ward
#3 Post by Evans Ward » Mon Dec 03, 2018 1:36 pm
Can you post a pic? I’m running stockers and have rebuilt mine many times and may be able to help.
Evans Ward
#4 Post by Evans Ward » Mon Dec 03, 2018 1:40 pm
RZ stock carb diagram
Does this help?
Evans Ward
#5 Post by Evans Ward » Mon Dec 03, 2018 1:41 pm
Is it #3 listed above?
hotshoe93
#6 Post by hotshoe93 » Mon Dec 03, 2018 2:13 pm
I was thinking my extra spacer (4.8mm) went in The #4 spot but I put in that spot it seems to be just a tad big.. I know 2 and 3 are correct I have a small,thin (washer/spacer maybe .5mm)) in the 4 spot now. Maybe the .5mm pacer goes in spot 1 and I could try to but the extra one (4.8mm) that I have in #4 again ?? your showing #1as a medium spacer, have any idea the width of it ?? I assume the #1 and #4 positions u a r pointing to are under the3 screwed cap ?? Thx a bunch.. I third to post a pic but not sure how yet as it says file is to big,. kinda new at this...
1 more thing I don't think my parts book / manual shows any spacers in the #1 position.
are # 1 #2 the same size ?
84 RZ350 Toomey
BULTACO ASTRO
:smt026
