Banshee Exhaust Question
On the OEM microfiche for the (1990) Banshee, it shows an exhaust flange o-ring.
No part number is listed for the o-ring.
Does anyone know the o-ring part number or size?
Why is there no part number? Seems like that o-ring would be changed often.
Re: Banshee Exhaust Question
looks like number 4 is your answer 93210-45742-00
#4 looks like an o-ring that goes between the pipe and stinger.gpaddict wrote:looks like number 4 is your answer 93210-45742-00
Want the o-ring/gasket that goes between the engine and pipe.
It is #4. They only show it for one pipe because it is the same for the other. #3 is the springs, #4 is the seal and shows quantity of 2. https://www.cmsnl.com/yamaha-yfz350a-ba ... 6BsuuTQaUk" onclick="window.open(this.href);return false;
Read the description and part #s here in this eBay listing Pete https://www.ebay.com/itm/Yamaha-Banshee ... SwZrdbP4ur" onclick="window.open(this.href);return false;
Got it!gpaddict wrote:looks like number 4 is your answer 93210-45742-00
Thanks. Had to look at the fiche a couple of times.
Thanks. Just needed a little help.silverstrom wrote:It is #4. They only show it for one pipe because it is the same for the other. #3 is the springs, #4 is the seal and shows quantity of 2. https://www.cmsnl.com/yamaha-yfz350a-ba ... 6BsuuTQaUk" onclick="window.open(this.href);return false;
I have some billet (Banshee) exhaust manifolds. Looks like an o-ring is supposed to go between the manifold and pipe header.
Hmmmm, can you post a pic of these parts? I can't quite complete the mental picture of what you're saying. Do some aftermarket banshee cylinders have a bolt on exhaust manifold?
If you’re using pipes with billet manifolds, then their usually is a sealing o-ring between the pipe and the bolt on manifold. Then your standard and crush gasket between the manifold and the barrel
Probably should have said pipe flanges, instead of manifolds.
Need to get the o-ring size that goes between the billet pipe flanges and pipe.
There are also o-rings between the billet flanges and cylinders, but it's a different size.
All I could think of was that you were trying to put banshee cylinders and pipes on your project!
- Evans Ward
Smoker- are you looking for the Banshee sized O ring for your application? If so, I may have some Toomey ones to give you if they are the same?
That would be great!Evans Ward wrote:Smoker- are you looking for the Banshee sized O ring for your application? If so, I may have some Toomey ones to give you if they are the same?
PM sent.
