installing set of power valves
jimrd
#1 Post by jimrd » Fri Feb 02, 2018 10:06 am
hi
I searched the search engine first.... :smt024
what is the best way to install the power valves
should I use two stroke oil for lubrication !
Grease, white
I know I have them in the right jug left and right... LOL
thanks
jim
1964 Austin Cooper S 1071cc
1967 Austin Cooper S vintage race car
1999 Ducati ST 4
1981 RD350LC , R1 Front,toomey pipes, Barnet Clutch, ported , PJ carbs, R1 Speedo 01
1983 RZ 350 - stroker bike,R6 rear shock,tapered stem bearings,progressive springs,
sedsberg
Re: installing set of power valves
#2 Post by sedsberg » Sat Feb 10, 2018 1:43 pm
They are going to be blazingly hot, so I doubt any grease or lube will hold up. They just need to be clean.
1990 RD350 F2 1WT
jimrd
#3 Post by jimrd » Sat Feb 10, 2018 1:58 pm
sedsberg wrote:They are going to be blazingly hot, so I doubt any grease or lube will hold up. They just need to be clean.
thank you
I cleaned up the parts
installed two stroke shop power valves along with new holders and o rings and seals
then put a little two stroke oil on seals and seals
all together
just waiting for the cases to come back from machining
1999 Ducati ST 4
hablair
#4 Post by hablair » Sun Feb 11, 2018 10:54 am
Don't they use a high temp moly? grease on them?
I'm sure I read it somewhere
T.RexRacing
#5 Post by T.RexRacing » Sun Feb 11, 2018 12:11 pm
That's what I've always used. Very Sparingly.
Salvador Dali
evan_calgary
#6 Post by evan_calgary » Tue Feb 13, 2018 7:29 pm
Ever motor I have had apart is well lubed with unburned 2-stroke oil. They wind up full of carbon and 2-stroke oil. I see no need for lube but it can't hurt.
jimrd
#7 Post by jimrd » Tue Feb 13, 2018 7:51 pm
evan_calgary wrote:Ever motor I have had apart is well lubed with unburned 2-stroke oil. They wind up full of carbon and 2-stroke oil. I see no need for lube but it can't hurt.
I just put very little around the lip of seals and o rings
So I would not damage the o rings pushing them
In
1999 Ducati ST 4
hondaror
#8 Post by hondaror » Wed Feb 14, 2018 12:51 pm
Keep in mind that just about every RZ out there is running too rich. This is why there is so much oil and carbon build up in the power valves and pipes.
I have 8 sets of stock pipes hanging in my garage. Every time I go near them, I nearly gag, as they are so plugged up with hydrocarbons. I will soak them all to clean them out in the future. The gag reflex is a constant reminder that I have to do so.
evan_calgary
#9 Post by evan_calgary » Wed Feb 14, 2018 8:44 pm
Rory,
We will have to get one of the TZRs on the dyno and see what you can do?
hondaror
#10 Post by hondaror » Wed Feb 14, 2018 11:03 pm
How many TZRs are we talking here? Lol
