vacuum line on right Carb
kampinguru
#1 Post by kampinguru » Thu Nov 16, 2017 11:58 am
Does anyone have a diagram that show the vacuum line port on the right hand carb. I cant remember which port it connects to. It is for a 1989 F2. thanks
RuZty
Re: vacuum line on right Carb
#2 Post by RuZty » Thu Nov 16, 2017 7:58 pm
The brass one near the front of the carb on the inboard side;
The pic is for an earlier VM26, but it should be in a similar location on the power jet version, it'll go straight through to the venturi downstream of the slide.
kampinguru
#3 Post by kampinguru » Fri Nov 17, 2017 8:53 am
Perfect. Thank you very much.
