Joined the (RZ) Chernobyl Club
Re: Joined the (RZ) Chernobyl Club
.0025 is way too tight, wiseco had problems years ago with cilicone content being wrong, they have a good piston now but that is too tight, I'd run it .0035 to .004 and let it rip
If you shut the throttle after a long blast and your idle screw/pilot jet is wrong ie to weak it will lock solid at those temps. Pilot jets flow all the time not just at low throttle openings. So you may have gone from good mixture to lean in a split second. EGT is a mine field as the probe has to be fitted with the bike in perfect setup then that is the EGT for that bike and that bike only.
Wossner is another forged piston supplier and have a very good track record.
I am surprised as rich as that motor is the egt's were that high, you said the head is cut, what is your squish clearance?
WFO for 45 years
1973 Yamaha TX750
1975 Yamaha DT400
1974 Norton Commando 850
Triumph Tiger 1050
Triumph Rocket III
1973 Yamaha TX750
1975 Yamaha DT400
Triumph Tiger 1050
Triumph Rocket III
Since all sorted out & running well. The plating on cast iron was not reliable. 3 failed attempts.
WFO for 45 years
1973 Yamaha TX750
1975 Yamaha DT400
Triumph Tiger 1050
Triumph Rocket III
1973 Yamaha TX750
1975 Yamaha DT400
Triumph Tiger 1050
Triumph Rocket III
- Redline Junkie
Did you pressure and vacuum test the engine once assembled? I do it every time I have the top end apart.concours wrote: ↑Sat Sep 03, 2016 9:17 amRuZty wrote:I think Wiseco call for .003-.004" for a 66mm bore. How did you measure it? RHS might have not been far behind, it had to start somewhere. Are you sure you had no air leaks?concours wrote: E) Piston clearance set at .0025", RH side lived just fine, despite a pegged temperature reading.
As sure as I can be no air leak. I meticulously assembled, new crank seals, Yamabond cases, reed blocks cleaned, inspected, gasketed (included Loctite 518)
1987 RZ350 Stock
1985 RZ350F basket case
1985 RZ500 Stock
1987 RZ350 Stock
1985 RZ500 Stock
2mm, IIRCGus the crank guy wrote: ↑Tue May 22, 2018 4:46 pm I am surprised as rich as that motor is the egt's were that high, you said the head is cut, what is your squish clearance?
WFO for 45 years
1973 Yamaha TX750
1975 Yamaha DT400
Triumph Tiger 1050
Triumph Rocket III
1973 Yamaha TX750
1975 Yamaha DT400
Triumph Tiger 1050
Triumph Rocket III
Didn't see this mentioned. I had that done on a small bore 50cc road racebike. Came off in first race. Then I sent it to US Chrome. Lasted 10 yrs of abuse to 14,000 rpm and had worn after lots and lots of hours, a bit, used with say 20 single rings and 4 pistons, but never flaked.
I have the KOSO with rapid response probes. I located them 6" from the bore, per their instruction. Any comments?kenny wrote: ↑Mon May 21, 2018 5:27 am If you shut the throttle after a long blast and your idle screw/pilot jet is wrong ie to weak it will lock solid at those temps. Pilot jets flow all the time not just at low throttle openings. So you may have gone from good mixture to lean in a split second. EGT is a mine field as the probe has to be fitted with the bike in perfect setup then that is the EGT for that bike and that bike only.
WFO for 45 years
1973 Yamaha TX750
1975 Yamaha DT400
Triumph Tiger 1050
Triumph Rocket III
1973 Yamaha TX750
1975 Yamaha DT400
Triumph Tiger 1050
Triumph Rocket III
Concours wrote: [resealed the crank, repaired the bores, added EGT's and observed reasonable temps, around 1200F at WOT short pulls. BUT, the coolant temp was always high. After 350 miles I cranked on it, redlined 3rd, 4th, 5th... resulting in coolant temp pegged, coolant overflowing the reservoir, and a light seizure. EGT max temp logged at 1450, obviously China Syndrome.]
Most aluminum alloys melt at around 1220 degrees F. so 1200 degrees is far from reasonable, it's on the edge of melt down!
66mm bores makes the liners really thin and more heat transfer to the coolant and possibility of overheating.
AMA No.1plate holder x2
I am having doubts about the vacuum petcock. Performs as designed as far as I know. BUT, I theorize, under low vacuum (WOT) it closes or restricts flow. Any users ever able to prove/disprove this theory?RZtuner wrote: ↑Wed Aug 17, 2022 2:14 pm Concours wrote: [resealed the crank, repaired the bores, added EGT's and observed reasonable temps, around 1200F at WOT short pulls. BUT, the coolant temp was always high. After 350 miles I cranked on it, redlined 3rd, 4th, 5th... resulting in coolant temp pegged, coolant overflowing the reservoir, and a light seizure. EGT max temp logged at 1450, obviously China Syndrome.]
WFO for 45 years
1973 Yamaha TX750
1975 Yamaha DT400
Triumph Tiger 1050
Triumph Rocket III
1973 Yamaha TX750
1975 Yamaha DT400
Triumph Tiger 1050
Triumph Rocket III
