TM 32 jetting
Bngt
Re: TM 32 jetting
#121 Post by Bngt » Sat Jan 18, 2014 7:06 am
I have heard of carbs without main jet however I cannot remember which ones.
F2 1986 project (ZX636R suspension)
F2 1987 The mule, test bench for tuning.
31K 1984 Donor
TZR 2MA 1986 Racer
TZR 2MA 1987 Stock
ZX10 1988 Cruiser
VTR 2005 (with CBRRR suspension, brakes and wheels)
Husaberg FS 570
GSX-R 1000 K5
Bngt
Re: TM 32 jetting
#122 Post by Bngt » Sat Jan 18, 2014 7:16 am
One thing to consider which we have discussed earlier is that it is not at the specific point of one restriction being smaller than the other it completely takes over control of flow. Two restrictions in series which are close in size will restrict more than just the smaller one. Therefore if the "handover is happening at 90% throttle it could be that the main jet contributes to restricting flow already from 80% and that the needle jet continues to restrict flow somewhat all the way to 100% throttle.
I found in my trials that a smaller needle jet and larger main jet was equal to a larger needle jet and a smaller main jet at full throttle. I was able to find combinations that worked at 80% and others that worked at 100% and in the end I found a combination that worked at both 80% and 100% at a large rev span.
31K 1984 Donor
TZR 2MA 1986 Racer
TZR 2MA 1987 Stock
ZX10 1988 Cruiser
Husaberg FS 570
GSX-R 1000 K5
Bngt
Re: TM 32 jetting
#123 Post by Bngt » Sat Oct 03, 2015 4:49 pm
Just to keep track of my changes and share experience I post again my updated spec. I have tested larger Main Jets and gone from 290 to 360. It has helped a lot at full throttle were there before was no gain the last 1/4.
1987 F2
Ported but with stock port timing.
Reduced squish same CR.
Kenny pipes
TM32
V-Force 4 reeds
Reed spacers
K&N
Zeeltronic
1000 18
1500 20
3000 24
4000 25
7000 25
8000 22
9000 17
10000 14
11000 11
Powervalve
4300 0
8100 100
Mikuni TM32
Main Jet 360
Needle jet 389 P6
Needle 5FP17 at mid notch
Pilot jet 27.5
Air Screw 1/2 turn
31K 1984 Donor
TZR 2MA 1986 Racer
TZR 2MA 1987 Stock
ZX10 1988 Cruiser
Husaberg FS 570
GSX-R 1000 K5
Bngt
Re: TM 32 jetting
#124 Post by Bngt » Wed Sep 12, 2018 3:53 pm
After some more jetting work on my 421 I went back to the Yamasaki and started to lean out a bit with great result. I have lowered the needle two notches and ordered Needle Jet P4. I have also gone back to 290 Main Jet.
1987 F2
Kenny pipes
TM32
V-Force 4 reeds
Reed spacers
K&N
Zeeltronic
1000 18
1500 20
3000 24
4000 25
7000 25
8000 22
9000 17
10000 14
11000 11
Powervalve
4300 0
8100 100
Mikuni TM32
Main Jet 290
Needle jet 389 P6
Needle 5FP17 at first notch
Pilot jet 27.5
Air Screw 1/2 turn
F2 1986 Yamasaki (ZX636R suspension)
31K 1984 Donor
TZR 2MA 1986 will get a 472
TZR 2MA 1989 421
BMW K1200 GT Cruiser
Husaberg FS 570
GSX-R 1000 K5
31K 1984 Donor
TZR 2MA 1986 Racer
TZR 2MA 1987 Stock
ZX10 1988 Cruiser
Husaberg FS 570
GSX-R 1000 K5
Re: TM 32 jetting
#125 Post by hondaror » Thu Sep 27, 2018 11:41 pm
Lectrons have no jets. They use a metering stick.
Boris_Sciaroni
Re: TM 32 jetting
#126 Post by Boris_Sciaroni » Sat Jul 17, 2021 10:07 pm
Hi, I have followed all the posts on this topic. At the end of your tests, what were the best settings with the TM32?
