Oil feed line broken
- Consciousness
I was attempting to richen the mix on the carbs a bit since we had such cold weather here in NYC recently, i can usually tug off the oil feed line to pull out the carbs to get to adjust the clip but due to the cold it just snapped where it joins the carb leaving me with a shorter line, i managed to get it back on but it split a little at the end and there is no more line to play with.
The line is a black hard nylon material and seems not to be the best stuff during the cold, is there something i can get locally that would replace it? My carbs are VM30's that have been drilled for oil injection with double flange tapered fittings.
85 RZ350 KR. Racetech/Fox Motul 10W. Telefix, Prog. Zeel, VForce4's, VM30 Mik's Uni-Filters & UFOs, Grooved Head & Mild Port w/Boyesen's by Rich's Taylor'd Porting, Orig. Toomeys, Redline, Conti Attack2.
Re: Oil feed line broken
get some from yamaha, its cheap as chips David.
aftermarket lines seem to get very hard and brittle....I changed to OEM and they stayed much softer..... easier to remove and reattach.JonW wrote:get some from yamaha, its cheap as chips David.
1973 ct70
1974 xr75
1977 rd400
1981 rd350lc
2002 zrx1200
1974 xr75
1977 rd400
1981 rd350lc
2002 zrx1200
and the only line approved by Arrow. its something like $6 from yamaha...
Its purpose made for that job, from the correct material.JonW wrote:and the only line approved by Arrow. its something like $6 from yamaha...
yep and at the price its a no brainer, but the Arrow seal off approval means more to us than Yamaha's these days when it comes to pumps :)
I always try my best to help people and keep these fine machines running as they should.JonW wrote:yep and at the price its a no brainer, but the Arrow seal off approval means more to us than Yamaha's these days when it comes to pumps :)
and we love you for it Gary! :)
Anytime mate, I will have at least 1 more pump for you to wave your magic hands over in the near future :)
