fbman
#1
Post
by fbman » Sat Apr 16, 2011 6:28 am
Open To suggestions???
What type of glue should I use to glue the mirror rubber boots to the upper fairing?
I just picked up a pair of used RZV mirrors and it seems that the mirror rubber boots will need to be securely glued to the upper fairing as they may have shrunk just a little bit with age... Thanks...
86 RZ350S -Mostly stock, Intake + Toomie Pipes
88 FZR250 -Stock
2004 BMW F650GS
1976 BMW R75/6 main ride
1989 Yamaha TDR250
rzatch
#2
Post
by rzatch » Sat Apr 16, 2011 7:48 am
They came pre glued, peel and stick new. I would use weatherstrip adhesive.
aaronmvrider
#3
Post
by aaronmvrider » Sat Apr 16, 2011 8:47 am
something not too aggresive... or hard ....perhaps a silicon style adhesive
my rides
rz 500 1984
2 x rz 350 1984
mv agusta f4 1000 2004
rzatch
#4
Post
by rzatch » Sat Apr 16, 2011 6:47 pm
weather strip adhesive can go hard but is easy to remove. But a good silicone adhesive would work as well. Just don't use super glue
I recommended weather strip glue as I bought new ones and the glue the factory used was marginal at glueing them down.
fbman
#5
Post
by fbman » Sun Apr 17, 2011 6:50 am
Thank you for your help guy's.
I'm giving the weatherstrip adhesive a try...
Looks to be holding okay, even with the cold
temps here today...
Frank B.
88 FZR250 -Stock
2004 BMW F650GS
1989 Yamaha TDR250
johnnyrotten13
#6
Post
by johnnyrotten13 » Sat Dec 03, 2022 8:49 pm
just pull the mirror stork up till it traps the rubber against the faring on the inside job done.
Twinsport
#7
Post
by Twinsport » Wed Dec 07, 2022 4:07 am
What about windshield adhesive? It bonds to paint and rubber and is easy to work with.
/Steen
