simon#51
#16
Post
by simon#51 » Wed Dec 29, 2010 11:39 am
THANKS VERY MUCH,
A COUPLE OF THINGS STILL TO DO,
HARRIS OFFSET YOKES
DRY CLUTCH CONVERSION HALF WAY THERE!!
check out you tube rd500 long road and yzr500 rep on dyno.
cheers simon
s harris
Ax-Racing
#17
Post
by Ax-Racing » Wed Dec 29, 2010 4:51 pm
Hi Simon
can you share info about your dry clutch conversion ?
thanks
Alex
simon#51
#18
Post
by simon#51 » Wed Dec 29, 2010 5:18 pm
Yes,
i'll post pics and info soon, early stages yet though but got the concept we need, it's part rd500 and part ducati corse, and forgot to mention the other item to fit on the bike is my new xmas present of the wife, translogic dash
cheers simon.
s harris
Ax-Racing
#19
Post
by Ax-Racing » Wed Dec 29, 2010 5:41 pm
I'm Working on a similar project
mix for yamaha and ducati parts, but my big trouble is about
mantain rubber cushion or make a rigid assembly
what's your choice ?
Alex
alan child
#20
Post
by alan child » Wed Dec 29, 2010 6:42 pm
simon#51 love ur bike mate,i see the frontend was abit light in the youtube vid,nice work..
AKCoop
#21
Post
by AKCoop » Wed Dec 29, 2010 8:08 pm
What throttle block are you using?
Bike looks great!
geosot
#22
Post
by geosot » Thu Dec 30, 2010 4:46 am
AKCoop wrote:What throttle block are you using?
Bike looks great!
Looks like TZ250 either 4DP or 5KE.
simon#51
#23
Post
by simon#51 » Thu Dec 30, 2010 11:26 am
Yep,
Top marks, new 4dp .
s harris
simon#51
#24
Post
by simon#51 » Fri Dec 31, 2010 6:04 pm
HAPPY NEW YEAR TO ALL YOU GUYS
s harris
rockit
#25
Post
by rockit » Sat Jan 10, 2015 2:11 am
- Hi amazing workmanship , question , did you use stock intake elbows for your carbs ?? and spacer blocks at the reed block ? is the r6 swinger a direct bolt on thanx in advance ,, yes im a noob but a cool cat 2 stroker learning the hard way ,, cheers
- diapo12dd260776b43b35b698a3d750064bb2.jpg (214.4 KiB) Viewed 2434 times
pstamper
#26
Post
by pstamper » Mon Jan 12, 2015 8:12 pm
How does the aluminum frame do at the track? Have you always ridden the aluminum frame or have you ever used a steel one. I was concerned the aluminum one would not be as stiff. I heard they were a little flexi. If those are the actual tires used on the bike it appears to handle pretty well. I thought of getting a steering damper but was getting the one that clamps to the top triple. I think it would be a good investment.. Appears you race a bit. What weight are you and do you know what all your fork setting are? Great looking work.
