Just re-built my MC with a factory kit and I am having a helluva time to get any pressure at the lever. Some other posts have alluded to some difficulty getting this syst em properly bled. My calipers are not seized and I have removed, cleaned and reinstalled my bleed nipples.
Any suggestions out there?
Bleeding the front brakes
Think like a bubble! I got a tip off here to take the master cylinder off and hold it 'lever up' and pump gently, worked instantly. Put the cap on first though!
I have taken the anti-dive lines off but I still don't have a solid feel yet.
It is possible to assemble the master cylinder valve the wrong way round, I ran a bike workshop and let the mechanics reseal my FJ1200 brakes but it just would not bleed or pump up, I found the problem myself and it bled easily.
Tip.... bleed brakes the best you can - at least so you've got "some" pressure. Top off all fluid levels, seal everything off, and then pull in the brake lever to the "pressure point" and zip-tie it there. Leave it like that to "stew" for a couple of hours, go drink beer, then cut zip tie. Voila - instant top-notch brakes.... (But don't road test till next day.... )
Actually, the magic is just the constant, long-term pressure, by zip-tying the lever in that position, that breaks up all the small air bubbles in the lines...
Works for me every time...
brakes
You can get a banjo bolt with a bleed nipple in it that you use where the hoses come out of the master cylinder. This allows you to bleed to the highest point - at the master cylinder. You should be able to get one at any decent bike shop or brake shop
Lynton
Lynton
