47X AND 1GE WHAT THINGS ARE DIFFERENT ?
Re: 47X AND 1GE WHAT THINGS ARE DIFFERENT ?
Hi all.
I found another difference.
On 47X there are 2 covers on top of rear pipes end bolted on sub-frame that didn't make it in 1GE.
Items 22 and 23, and the stay 12 has a different part number.
Also on 1GE there is a new protector, item 23.
- jackson.40
phildu31 wrote
Here are some photo's of these items only fitted to the 47X spec bikes.
Items 22 and 23
- jackson.40
47X and 1GE frame differences (work in progress)
47X FRAME
Front fairing stay mounting bracket and steering lock bracket
Rear swinging arm relay arm mounting
1GE FRAME
47X FRAME
1GE FRAME
- jackson.40
The 47X and 1GE wiring looms are different.
The 47X bikes had wiring loom part number 47X8259070
This loom hasn't got the extra earth terminal which goes on the lower reg screw on the 1GE bikes
The 1GE bikes had wiring loom part number 47X8259071
This loom has an extra earth terminal which goes on the lower reg screw as seen in this photo
Never realised these were not 1ge items, they were hard to find as well! Mine is such a Heinz57 now...
RD500
TZR250 2MA
TZR250 3MA
TDR250
YZF600R
DT125RE
XS750E
DTR125
FZ1
TZR250 2MA
TZR250 3MA
TDR250
YZF600R
DT125RE
XS750E
DTR125
FZ1
- jackson.40
They tend to crack around the mountings, i think over the years owners took them off and lost them
Stevejackson.40 wrote:The 47X and 1GE wiring looms are different. (work in progress,more photo's to come tomorrow)
I have a 1986 52X loom (52X-82590-51). Should you ever decide to add this to your list let me know and I'll get photos for you.
John
- jackson.40
Thanks John
- jackson.40
- jackson.40
The 47X and 1GE rear mudguards
47X REAR MUDGUARD
Part number 47X2161100
The 47X bikes had a problem with the rear mudguard melting on the upper exhausts so a heat protector was added to the 1GE bikes
This is a 1GE rear mudguard without the heat protector fitted which has melted
1GE REAR MUDGUARD
Part number 47X2161101
Because of the upper exhaust melting the rear mudguard on the 47X bikes Yamaha fitted a heat protector to the 1GE bikes.
One thing i am not sure about is did the 1GE bikes leave the factory with only one heat protector fitted to the right hand side(the 1GE pre-production bikes only had one fitted to the right hand side)or if two were fitted?
Could someone check their bike for me?
This is a photo of the 1GE Pre-production rear mudguard with only one heat protector fitted
The heat protector came as a set from Yamaha part number 1GE2165200
47X REAR MUDGUARD
1GE REAR MUDGUARD
- Speed Freak
Only right side on mine.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
Speed Freak wrote:Only right side on mine.
Same, just the one heat shield on the right...was a good excuse to pull the cover off and have a look at her..
Really interesting thread Steve, keep up the good work.
My spare fender has only one and it's on the right side.
- jackson.40
Thanks for checking guys
Happy New Year!!
Happy New Year!!
- jackson.40
CDI Units are different between the 47X and 1GE
47X CDI UNIT
1GE CDI UNIT
Also the Flywheels are different
47X8145050 ROTOR ASSY MARKED 47X-50 FITTED TO 47X TYPE BIKES
47X8145051 ROTOR ASSY MARKED 47X-51 FITTED TO 1GE TYPE BIKES
More info here.............
http://www.rzrd500.com/500phpBB3/viewto ... t=flywheel" onclick="window.open(this.href);return false;
47X CDI UNIT
1GE CDI UNIT
