With a battery eliminator on a stock rz500
What will happen whit the
batt pac
No Battery.. No Problem
So a little "error" and some "trial" later I was able to play lab-rat for this one. When purchasing an RZ a while back- the original owner sold the bike with a battery in place- uncharged. The condition of the bike was "not scottish" (or "crap") but the electrical components worked fine and the although the YPVS doesn't cycle- at start Smurph's on the money- the valves are in the same position at idle/start.
..."so why not remove the battery?" so i did, and found that you can ground the negative wire, cap the positive, and voila- "no battery required"
I run the stock lights, and they aren't exactly "piercing the darkness like a laser beam" ...but all lights, and indicators work- albeit with a slight "dip" when you grab the brake lever. I noticed this effect previously, when an undercharged battery was in-place- but the effect is much less pronounced, WITHOUT the battery (as opposed to a "low" one)
I'm also convinced that it can't be that simple...but I haven't noticed any changes to the way the bike runs, and apart from one blown fuse- it was a helluva lot cheaper than a gel-pack.
motorcycles are in my blood...but my body needs new tires.
