The Burning Question...?
Re: The Burning Question...?
#46 Post by silverstrom » Thu Dec 14, 2023 3:19 pm
giron wrote: Thu Dec 14, 2023 3:01 am John you should have said this earlier and saved all the time praising Wiseco. The OEM pistons no need for warming like the Wiseco
It's clear now that all you are here for is to argue. Why be here if you have nothing positive to offer? You never post anything that is helpful.
Once again George, stock Yamaha pistons only come in two over-bore sizes. 0.50 mm O/S max. If you need more that the 2nd oversize you need to go aftermarket. Wiseco is a good choice for most people because they have the common sense to understand the difference between cast and forged pistons. Some people that don't understand the properties of forged pistons go around telling people Wiseco pistons are a bad choice, but only because they can't understand the basic differences between cast and forged pistons, no matter how many times it is explained to them.
giron
#47 Post by giron » Thu Dec 14, 2023 4:07 pm
well John
I see that you like to continue with this thread where you again you accuse me of not contributing anything to this forum. Are liners available for the RZ500 cylinders. I need to ask you since you are very knowledgeable on the RZ500. You can enlighten us with such knowledge. You are the one that enlighten us with an alternative with Yamaha OEM pistons. Now as far as myself not contributing anything on this forum. I manage for you to admit an alternative to Wiseco pistons that are not required for special starting procedures. The next thing their was a post on removing an RZ500 tanks with gasoline in it and causing a leak. I posted the alternative a TZR250 3MA petcock that would bolt to the tank and it has the same hoses as the RZ500 petcocks. Yes a small alteration may be required on the small aluminum plate. I'm sure everyone in this forum appreciates me in extracting knowledge from you
1985 RG500(Walter Wolfe)
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
phildu31
#48 Post by phildu31 » Thu Dec 14, 2023 4:25 pm
silverstrom wrote: Thu Dec 14, 2023 3:19 pm
I totally agree with you John.
giron
#49 Post by giron » Thu Dec 14, 2023 5:17 pm
I’m a member of this forum since it’s started. Now if John has an opinion since he knows so much. I like to hear it with the different options. The same way he feels that Wiseco pistons are the greatest and can walk on water. I have the right to post they are junk. As you read before OEM pistons are more expensive but no need for special starting procedures.. if you have something constructive to say I like to hear it without the threats or insults.
I obviously have posted here constructive information if you go back at the start of this forum.All it takes some time in doing your homework
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
lucky mike
#50 Post by lucky mike » Thu Dec 14, 2023 6:46 pm
Drawing a parallel between the choice of forged and cast pistons and claiming one as universally superior would be akin to asserting that one motorcycle model, such as the RG, is inherently better than another, like the RD. In both cases, the optimal selection hinges on the intended purpose, performance demands, and overall objectives, emphasizing the need for a nuanced evaluation rather than a blanket preference. This is another universal truth...
#51 Post by silverstrom » Thu Dec 14, 2023 7:42 pm
Well said Mike, and the point Tacky1 and I were trying to make. It's subjective to the intended purpose, but by no means are forged pistons to be avoided based on biased opinions by those who have never used them, or who have and been reckless with their use.
#52 Post by Smoker » Thu Dec 14, 2023 8:50 pm
lucky mike wrote: Tue Dec 12, 2023 9:14 am My RZ is stripped down to parts small enough to fit into plastic tubs and repurposed yogurt containers.
I am no stranger to motorcycle maintenance and tuning,
Asking again if you can post some pics of this bike/parts. You know, the kind of pics taken by an actual human. Thanks. :smt023
giron
#53 Post by giron » Thu Dec 14, 2023 9:37 pm
John
You are correct. I only care for OEM.
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
lucky mike
#54 Post by lucky mike » Thu Dec 14, 2023 9:58 pm
I would be happy to post some pictures Smoker...as soon as my wife gets home and tells me where she hid the USB that connects my Iphone to this antiquated PC...
lost1750GTV
#55 Post by lost1750GTV » Fri Dec 15, 2023 12:28 pm
"Get back to the burning question"
There's a good thread from oct 9, 2006, called "TSI porting" with some comparative dyno charts from rztom, and references to others.
You might also search for dyno and pipe comparisons - jollies raise peak power to 10600 if I remember correctly, so if you have the carbs & cleaners to feed that, 100 (or close enough/feels like) doesn't seem too hard to achieve.
That's assuming 88 stock, and getting about a 12% increase.
lucky mike
#56 Post by lucky mike » Fri Dec 15, 2023 4:31 pm
I recently had the privilege of engaging in a compelling conversation with Bill Wilson. The discussion, spanning over an hour, left a profound impression on me as he emerged as a remarkably humble and exceptionally knowledgeable individual. Throughout our dialogue, he generously shared a plethora of experiences, regaled me with some genuinely amusing anecdotes, and, with utmost consideration, conveyed that the timeline I had envisioned for my engine project might not be feasible. Disappointing as this revelation was, Mr. Wilson's forthrightness about aiming to deliver completed engines by 2025 provided valuable clarity. Despite the adjusted timeline, I find his candor and expertise to be invaluable, and I look forward to exploring potential alternatives for my project with his guidance.
Interestingly, but not unexpectedly given his character, Mr. Wilson suggested that I reach out to Andrew Jones of ATR. He spoke highly of Mr. Jones, emphasizing their relationship that spans several years. The recommendation struck a chord with me, given the invaluable insights Mr. Wilson shared during our extensive conversation. It appears that seeking assistance from ATR for the next phase of my project is a natural progression, supported by the glowing commendations and long-established professional rapport between these two experts.
My next call will be to Andrew Jones of ATR.
#57 Post by silverstrom » Fri Dec 15, 2023 5:03 pm
You have PM
#58 Post by Smoker » Sun Dec 17, 2023 2:37 pm
A couple of pics from Mike. There are more, but just normal teardown pics, so far.
Jeff B
#59 Post by Jeff B » Mon Dec 18, 2023 3:07 pm
Looks like it was piped when you got it. What kind of pipes are they? Jolly Moto's perhaps?
lucky mike
#60 Post by lucky mike » Mon Dec 18, 2023 11:07 pm
Hello Jeff,
You're absolutely right, Sir! I fitted those pipes approximately nine years ago. However, don't let the image deceive you. While they may appear pristine in the photos, the reality is vastly different. The relentless battle against surface rust has proven to be quite the challenge. After much deliberation, I've reluctantly come to the decision to have them ceramic coated as part of this ongoing build. It pains me to think about losing the visual charm of those exquisite welds that truly make these pipes a work of art. Yet, the persistent onslaught of surface rust has taken a toll on their overall appearance, and I believe the ceramic coating is a necessary evil to preserve their integrity.
It truly breaks my heart, but it needs to be done.
