YPVS Curve with Jollymoto and Modificate YVVS unit
rammstein86
#1 Post by rammstein86 » Thu Jun 01, 2023 1:04 pm
Hi
I have a two stoke racing lab modificate YPVS unit and i want your advice :
What is the better curve o use with a RD500 engine stock but with Jolly Moto exhaust ? To have a good bike, who is pleasant to ride ?
YPVS opening soon or later ?
rz500guytexas
Re: YPVS Curve with Jollymoto and Modificate YVVS unit
#2 Post by rz500guytexas » Fri Jun 02, 2023 3:17 pm
On my Zeel i used the 1GE curve. It runs as fast as I need and has done so for 7 years
Stinke
#3 Post by Stinke » Sat Jun 03, 2023 3:16 pm
I use the curve from the TSI-specs and have a later opening on the ypvs (zeeltronic) During braking in from honed/new pistons and mildly ported barrells i used 47x (rd500 -84 european) timing and after that changed to TSI......om my......unleashed 15-20hp easaly.
Best regards from Sweden
2 x rd 500 -84
Rd 350 ypvs -84
Rd 250 -74
Kh400, t20
The best of swedish metal: https://youtu.be/gkBt7yLXyDk" onclick="window.open(this.href);return false;
#4 Post by MK » Sat Jun 03, 2023 6:05 pm
Have a look here and check out curve 18 or 16.
https://www.rd350lc.de/downloads/MK-Dok ... cation.pdf
(Curve 18 equals RZ500 Mod_2 in your manual)
Or in other words: start opening around 7500-8000, end opening a few hundred rpm before peak rpm (10500 - 12000).
Unfortunately the stock controller has some 10500 as max rpm. For higher rpms you'd need a Zeeltronic or Ignitech controller.
rammstein86
#5 Post by rammstein86 » Sun Jun 04, 2023 1:53 am
Thanks a lot for advice
