Pistons. Yes that old chestnut
ChequeredFlagRacing
#1 Post by ChequeredFlagRacing » Sun Apr 23, 2023 6:41 am
Doing a re-bore and the guru tells me to go for 2ma or 2rk (early ones) and not to worry about windows for the upper pistons.
So who has the part numbers please for both types
TIA
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Yamaha AS3 125cc 1978
Yamaha AS1 125cc 1979
Honda CX500
Honda MT125cc 1980
Yamaha TZ125G 1981-82
Zeger TC500cc 1983-84
Yamaha RD500LC 1985-87
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Re: Pistons. Yes that old chestnut
#2 Post by silverstrom » Mon Apr 24, 2023 7:36 pm
You need TZR250 1KT, 2MA, 2ME, or 2MY pistons. Yamaha part number for std bore 56.4 is 99999-02108. That gets you set of rings and 1 piston as a kit. 1st oversize kit is (+.25) is 99999-02109. 2nd oversize kit is (+.50) is 99999-02110.
Use new Yamaha pins and clips and new Yamaha small end bearings.
Yamaha only supply up to 2nd oversize. If you need bigger than that you'll need another supplier.
2RK is TZ250, but the TZ part number supersedes to 99999-02108, so that simplifies your search.
Lots of discussion on this forum about using 4 TZR pistons.
ChequeredFlagRacing
#3 Post by ChequeredFlagRacing » Tue Apr 25, 2023 4:34 am
Thanks for the reply
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
rz500guytexas
#4 Post by rz500guytexas » Tue Apr 25, 2023 11:11 am
I would put what came in the bike. Proper pistons with windows if you can locate them
phildu31
#5 Post by phildu31 » Tue Apr 25, 2023 2:52 pm
rz500guytexas wrote: Tue Apr 25, 2023 11:11 am I would put what came in the bike. Proper pistons with windows if you can locate them
That is right when you don't understand how this motor works.
Otherwise, you can put TZR kits like I did nearly 20 000 kms ago.
vma500
#6 Post by vma500 » Tue May 02, 2023 12:31 pm
Pistons with Windows need richer jetting and richer jetting needs more ignition advance , it makes sence now ?
Tzrs with no Windows are perfect since the ignition is all same for all the 4 pots
V4 Stroker
#7 Post by V4 Stroker » Wed May 03, 2023 5:01 am
Ended up getting Mitaka TZR250 Piston Kits after chatting with Mick Abbey Tuning here in the UK
Just waiting on the re-bores to be done
