Just lost the mid-range on my modified RZV500R
rz500guytexas
Re: Just lost the mid-range on my modified RZV500R
#16 Post by rz500guytexas » Wed Jan 04, 2023 11:44 am
Sounds reasonable. Mine with oval bored carbs that Rick Lance did with pipes and Zeel is 90 and 47 ft lb. I believe around 9,500 to 10 k max power. Shift at that point or 9 when at the track. Those 4 carbs are a bitch.
rd84
#17 Post by rd84 » Wed Jan 04, 2023 5:41 pm
rz500guytexas wrote: Wed Jan 04, 2023 11:44 am Sounds reasonable. Mine with oval bored carbs that Rick Lance did with pipes and Zeel is 90 and 47 ft lb. I believe around 9,500 to 10 k max power. Shift at that point or 9 when at the track. Those 4 carbs are a bitch.
The carbs were hard work - they all ended up a little bit different on needle height - to my surprise the jets were leaner in the rear cylinders which was a first for me.
rz500guytexas
#18 Post by rz500guytexas » Thu Jan 05, 2023 10:17 am
Did his dyno do A/F ratio or CO. I take it no EGTs are installed. I always run the same main jets in mine. Could be float levels. But if it is running well, congrats.
rd84
#19 Post by rd84 » Fri Jan 06, 2023 7:50 am
rz500guytexas wrote: Thu Jan 05, 2023 10:17 am Did his dyno do A/F ratio or CO. I take it no EGTs are installed. I always run the same main jets in mine. Could be float levels. But if it is running well, congrats.
No EGT’s fitted . The dyno was a new Dynostars dyno z as nd it looked at A/F ratio’s
It was Dave at MuttsNuts who did the work.
rz500guytexas
#20 Post by rz500guytexas » Fri Jan 06, 2023 10:27 am
I tried to dyno my TZR and the reading showed way lean. I knew it was not bad jetting but jetted up and it would not run. Back to what I had and ran fine. I installed some EGTs and watched them. I bought a new sensor for his dyno and kept it. I knew doing a two stroke ruins the sensors so used my own. It plugged in the dyno fine but maybe was calibrated incorrectly.
