Hagon shock for rear?
Has anyone here used a Hagon shock on the rear of the RZ5? I wonder if a model 62045 or 900-147 will fit the bike? Online documentation seems to be lacking on the Hagon rear ...
Re: Hagon shock for rear?
Try contacting them and see if they can give dimensions would be best advice. Remember those shocks are a bit special because of the linkage ratio. The stock spring is 900 pounds or so i believe. Mine has an 1,146 pound sring i think. Might be 1,046. All I know is it is stout. I would think the internal buid would be different also due to the additional load and weight. A good shock will not be cheap and brakes and suspension are a few thing I would not chance with. You never know it was a bad choice until after the fact. Let everyone know if it is just for street riding, some track days, or track only.
