Sealing JL Exhausts
Sealing JL Exhausts
Hi,
Bit of a oily dribble from the JL expansion chambers where they connect to the cylinder not too bad, but I hate the mess they make - does anyone have any tips on the best method of sealing them - RTV Silicone , Fire Gum etc ? or is there a crushable gasket that would work ? - Strangely the JL's only have one spring per pipe.
Thanks.
Thanks.
Re: Sealing JL Exhausts
use rtv silicone, but make sure you clean any oil off first, that's what i always use
On the exhaust to stub I use https://www.screwfix.com/p/geocel-trade ... lsrc=aw.ds
Nikkon's use two springs per exhaust
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Yamaha AS3 125cc 1978
Yamaha AS1 125cc 1979
Honda CX500
Honda MT125cc 1980
Yamaha TZ125G 1981-82
Zeger TC500cc 1983-84
Yamaha RD500LC 1985-87
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Thanks for the advice guys.
After the JL orings failed I replaced them with these from McMaster-Carr supply. These with a bit of high-temp red silicone sealer sealed them…so far lol.
#1288N128 Chemical-resistant Vito fluoroelastomer o-ring, super resilient, 1/16 fractional width, dash no. 028, $4.33 for a pack of 5 (price is from a few years ago)
Thanks for the info.
It still seems strange that the JL’s only have one spring per pipe
One spring is strange. I would think the pipe woul move. Silicone after a very good cleaning took care of my Jollys
I've just siliconed the pipes for a second time - the first attempt failed - I found it quite hard to put a bead on the exhaust flange - I had to rely on coating the end of the pipe - I noticed a groove on the exhaust flange and wondered if a O-ring should go in it ?rz500guytexas wrote: ↑Sun Sep 05, 2021 10:00 am One spring is strange. I would think the pipe woul move. Silicone after a very good cleaning took care of my Jollys
Not sure it's the same problem but in the 500 factory days Honda and Team Roberts both sealed the inside of the exhaust with Nikasil.
I used these from McMaster-Carr USA with success, so far. Just did a track day and still holding.rd84 wrote: ↑Sun Sep 05, 2021 9:20 pmI've just siliconed the pipes for a second time - the first attempt failed - I found it quite hard to put a bead on the exhaust flange - I had to rely on coating the end of the pipe - I noticed a groove on the exhaust flange and wondered if a O-ring should go in it ?rz500guytexas wrote: ↑Sun Sep 05, 2021 10:00 am One spring is strange. I would think the pipe woul move. Silicone after a very good cleaning took care of my Jollys
Thanks for the advice everyone - I've used a high temperature copper silicone and put more on than before being careful not to get it inside the exhaust flange - right now I think its successful - I've bought some exhaust O rings in case my latest attempt fails
