The inside glass on my instruments are a bit grimy and I was wanting to give them a clean.
Does anyone know how the bezels are removed?
Thanks.
Instrument bezel
Re: Instrument bezel
I use a paint tin opener. Go around the edges and carefully pry out the sides. Go back and forth on them. Bit by bit. And you only need to do a little over half of it. It will slide up and off then. Clean up and refit and I press the edges back with a 1/4 inch long extension.
Done lots like this and they look great.
Just did this complete set this week. Lc350 clocks, but the same bezel idea.
I'll give that a go tomorrow.
Thanks for the advice.
Managed it. Only opened the rev counter as this was really dirty on the inside, clocks were ok.
Was a tricky job, just used a small flat screwdriver but got there in the end.
Thanks again for the info .
Great job, Another one saved
