180 rear tire with 3xv swinger?
Morning, hey just curious if anyone has fit a 180 and 5.5 rear wheel in a 3xv swingarm? My curiousity if getting to me on my ysr replica. It's a 3ma frame with 3xv swinger. was planning to stick to a 4.5 with a 150 rear but was curious to hear from anyone that has done it.
Re: 180 rear tire with 3xv swinger?
Yep, have done exactly that. Used a R6 fitment 5.5” carbon BST wheel with 180 rear tyre. Had to slim down the cush drive a little, but it does fit.
its easier if you use an R6 swingarm 2007 with its wheel
1985 RG500(Walter Wolfe)
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
A TZ250 3YL-4DP 5.5 should fit no problem
73 TM/TS400
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
21 Aprilia RSV4 1100
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
Steveho, do you think it is worthwhile fitting that much rubber? With the cf im sure you still have lower weight, but do you notice slower steering? I know its a tricky question, with a different swingarm, maybe ride height and fork angle altered as well - but aside from looking great, do you think there is a benefit to that much tire?
Mine's a YZR rep, so the wide rubber is part of the look. The build is still in progress, so haven't ridden it yet. However, it's got a 3MA frame, so 1 degree less rake than stock RD500, raised rear and 60 profile front tyre means it should turn quick enough...
If you use a 5.5 tire the 180 is fine. I have a 2006 R6 swingarm. Get the 60 profile and it will raise the back 10 MM if you use a Pirelli SC2 slick. The 60 profile was the final piece of the puzzle on my track bike. Both tires wear eqaully now. There are other things done such as shock and fork work. If it is show only heck with it.
Thanks everyone for the input! So i know RGVSteve used to do r6 swingers stateside for the 3ma frame. Is there anyone stateside that can do this now?
And the other question, the frame is setup for a 3xv shock and pivot, i'm probably going to have to change that with a r6 swinger correct?
520 non-oring heavy duty DID chain.innovativems wrote: ↑Tue Dec 01, 2020 12:07 pmThat's great to hear! What pitch chain are you running?
