1986S project. Question is the 86S wiring harness same spec as the 52X -84 models ? attempting to use harness from 84 model I totaled out, appears harness is tweaked
from wreck. looking for replacement wiring harness. If 86S is the same ill continue to search for used 52X harness, plus I've sent pm to forum contact which has sold reproduction harness.
1986S wiring harness
u r never to old to have a perfect childhood
Re: 1986S wiring harness
I have an 86S if you need any help with anything, i.e. what something might look like.
1986 RZ500S (Number 3 of 150)
1993 BMW K1100RT
2003 BMW K1200GT
1993 BMW K1100RT
2003 BMW K1200GT
pulled the 84 model harness out re-installed original 86S harness. noticed different part numbers, wire colors etc. started first kick.
so yes 86S has a different main wiring harness.
