Reliability
Reliability
I am looking at getting an rz500 that will probably need some engine work
I intend to tackle the job myself
I have heard these engines are fragile heard to work on and unreliable
I do not expeCT it to as reliable as a modern bike but just need some feedback before I get it
Re: Reliability
The engines themselves are pretty easy to work on. The upper cylinders are prone to problems. They run pretty hot. Up-jetting the uppers seem to sort the problem.
Re: Reliability
Just remember, back in the day these were sold from dealer showrooms with full warranty. The Japanese, being as they are would not accept any ‘lemons’.
Sure, they can be troublesome, but not really any more so, than any other 2 strokes. My RD500 has 42k miles on the clock. Ok it has been rebored once, and the cranks probably rebuilt in the past..., but if you want a 2 stroke, then this goes with the territory.
As stated, easy to work on, so don’t hesitate, get one and enjoy....
Re: Reliability
They are as reliable as any other 35 year old 2 stroke. Common sense and proper maintenance will help avoid any serious issues, but it is a 2 stroke and sometimes it all goes wrong for no reason.
All it takes is money and mechanical skills. If you are mechanically inclined and can afford the cost of the bike and the restoration you won't be disappointed with the end result.
The people saying they are fragile and unreliable are the people who don't own one.
Re: Reliability
this is my Casereed reed h2 on the dyno that i built, (130rwhp) so i am used to working on old two strokes. I was just curious about the RZ500 as i know nothing about them
https://www.youtube.com/watch?v=dIlhcYueWmM
Re: Reliability
Yeah, that'll do itcasereed3 wrote: ↑Fri Jul 31, 2020 7:34 pm this is my Casereed reed h2 on the dyno that i built, (130rwhp) so i am used to working on old two strokes. I was just curious about the RZ500 as i know nothing about them
Like most old smokers, parts are getting harder to find and more expensive. There is nothing you can't find and buy, but prices are a bit mental now.
Reliability is not an issue. It never has been. There are lots of stories, but as is typical, most are baseless.
There aren't many RZ500 problems that can't be overcome, engine included.
Are you planning on a stock build, or will you give it some of the treatment you gave the H2? After seeing the casereed H2 you may find the RZ500 a bit dull.
Where are you located?
- Mike Cichetti
Re: Reliability
Love to see more of your H2! Just finished restoring a stocker, waiting on master cylinder rebuild kit. Yours looks really super special.
Re: Reliability
I have seen that H2 up at Martin 131 Dragway
I go there when they have the snowmobile drags/2 stroke bikes
Cool bike
Cool bike
73 TM/TS400
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
21 Aprilia RSV4 1100
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
Re: Reliability
Do you have a build thread or something on the H2, That thing is a screamer
Re: Reliability
sorry no build thread as such but it has,
rgv 250 swing arm
kawasaki 636 front end with carbon rim
lock up clutch
zeeltronic ignition with Yamaha Seca pick ups
V force reeds
case reed induction all parts made by me but i did not do the welding
the cylinders were relined without the inlet hole in the rear as its case reeded. The cylinders do have rear boost ports that are fed thru a channel in the back of the cylinder that connects with the rear of the crank case.
Hydraulic clutch conversion using a Ducati slave cylinder
Busa, i am going to Martin this October, if i still have the bike i will bring it and you can take it for a spin
rgv 250 swing arm
lock up clutch
V force reeds
Re: Reliability
That would be real cool
I am hoping I can get up there this Oct.
There are a few guys running GT750's that I talk to when I am up there.
Every year they try to convince me to bring a bike up to race.
I never have a good reason why I don't, other than I hate sitting sweating in my leathers waiting to get up to the line.... Maybe October will be much cooler than Sept used to be.
If I do head up, I will try to take the RZV....have a set of new Mikuni needle/seats for the carbs on their way to me.
73 TM/TS400
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
Re: Reliability
You'd probably want to download and read this :
http://l3s9113.zeus09.de/RD350/Tuning_m ... Seiten.pdf
Re: Reliability
Hi,
I've owned and run RD500's since 1984 - I've found the engines to be very reliable - the main problem seems to be the fuel system causing problems due to age and corrosion - mainly caused by ethanol in the fuel - the problems extend from the tank, through the fuel tap to the carbs themselves. This can be alleviated by using a fuel stabiliser and adding a small mount of 2T to the fuel tank on each refuel.
Engine rebuilds can be very expensive if a full rebuild is needed.
Hope this helps.
Hope this helps.
