FUNC ME
FUNC ME
Was watching this video that was recently posted.
https://www.youtube.com/watch?v=ERUWFgfNHsM&t=16s
Learned about the RZV500 FUNC switch.
Didn't find any info on the switch, the fuel level sensor, or the dual gauge, in the service manual I have. Manual is supposed to cover the RZV500R.
So the RZV fuel tank is different?
Anyone try to retrofit a standard RZ500 with RZV fuel gauge parts?
Re: FUNC ME
Yep. The RZV tank has a fuel level sender for the gauge, Thats really it, The FUNC button just switches between the temp and the fuel level
here s the difference
https://auctions.c.yimg.jp/images.aucti ... e34016.jpg
Re: FUNC ME
No one would bother Pete. It's far too much in both cost and time. You would need the RZV tank, the RZV fuel level/float unit, the correct multi function switch and gauge (51X part #), and the correct wire harness.
Re: FUNC ME
Thanks for the info.
Is the petcock different, and mounted in a different place on the RZV500 tank?
Was just wondering if the RZ500 fuel tank could be modified to hold the RZV500 fuel level sensor? Then hooked up to an aftermarket gauge.
Re: FUNC ME
Same petcock and location, same filter in the tank also..
Re: FUNC ME
The RZ tank already has the square on the bottom, you would need to drill out the holes to fit it, Getting nuts on it would be a tough one, Maybe cut it out completely, tack on the nuts on the back and weld it back together.
ixe13's solution looks great, No FUNC button needed, Looks really nice actually...
Re: FUNC ME
2 x 2 bolts from the inside welded with a nail to bridge them so they won't spin freely + 4 nuts on the outside
Re: FUNC ME
Funny , you could use a right handle switch from a FZ and use the '' start '' button as the function switch .
Re: FUNC ME
Yep. That’s what I did on my RZV. The right switch is impossible to find in good condition.
Re: FUNC ME
Does the FZ750 temp / water gauge fit in the RZV mount without out modification?
Don't mind doing the wiring to bypass the switch
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Yamaha AS3 125cc 1978
Yamaha AS1 125cc 1979
Honda CX500
Honda MT125cc 1980
Yamaha TZ125G 1981-82
Zeger TC500cc 1983-84
Yamaha RD500LC 1985-87
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Re: FUNC ME
I took a few measurements and it wont fit.ChequeredFlagRacing wrote: ↑Sat Jul 25, 2020 6:30 am Does the FZ750 temp / water gauge fit in the RZV mount without out modification?
Re: FUNC ME
Not 'drop in' but also not impossible as its nothing a quick Dremel wouldnt fix tho? Its 3.5mm all round... You would also need to redrill the mounting holes as well I would think.
I guess it depends on how much you want to do it and how easy the brackets are to find?
Im wondering what is another bracket that fits the bike that uses this gauge? FZ750R maybe? you could fit the other clocks to that bracket perhaps? Ive no experience of these but lots of the Yam gauges of the era used a similar bracket is my thinking.
www.2smoked.com
82 RD250LC '251LC' YPVS
Re: FUNC ME
Thanks for taking the time to check
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
