Hi All
Can they be done with the motor installed?
I've compiled a list of the parts. Am I missing any items before I source the items?
Some will need more than one item
TIA
24 47x-1131E-00 Holder 1
25 93210-27370 Bolt
26 93210-27370 O-ring
27 47X-1131F-00 Holder 2
28 93210-27370 O-ring
29 93108-23010 O-ring
30 47X-11915-00 Plate Thrust 1
31 91311-05008 Bolt
Power Valve clean and service
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Yamaha AS3 125cc 1978
Yamaha AS1 125cc 1979
Honda CX500
Honda MT125cc 1980
Yamaha TZ125G 1981-82
Zeger TC500cc 1983-84
Yamaha RD500LC 1985-87
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Re: Power Valve clean and service
Motor installed, yes.
But you need to get off all 4 cylinders.
OK
Winter job then
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
It's bad, but not that bad. I did YPVS service and new rings a while back. I remember it as a 8 hour job, including a fair bit of frustration and cursing, but hey - isn't that what having a 500 is all about
/Steen
Necessary job.
Take your time and do it well : I advise you to remove the motor from frame even if it is not mandatory at the end it will be easier.
Make a leak test and see what you get.
Chances are that you'll find some leaks.
