Squish setting
General forum on engines, transmissions, gearing and modifications to each
Kgsdb
Squish setting
#1 Post by Kgsdb » Sat Jan 12, 2019 7:39 pm
Hi
Can anyone tell me the quish setting for a standard Rd 500 in mm useing solder wire in the plug hole and in cc useing fluid
Also what psi should I get with a compression tester after a top end rebuild
Any help much much appreciated
Thanks dave
Jeff B
Re: Squish setting
#2 Post by Jeff B » Mon Jan 14, 2019 3:13 pm
The squish is way to big in standard form. Probably different from front to rear as well.
PaulGreen
Re: Squish setting
#3 Post by PaulGreen » Mon Jan 14, 2019 4:51 pm
Dave,
The manual says you should get 128 psi.
Working towards that with my own bike.
Cheers,
Kgsdb
Re: Squish setting
#4 Post by Kgsdb » Mon Jan 14, 2019 6:12 pm
Thanks paul
