YZ85 reed valves.....are they worth the effort?
Re: YZ85 reed valves.....are they worth the effort?
Another interesting discovery searching on a Japanese web site.............possibly?
If anyone here can confirm or deny....
TZR50 reed valves/cages working on a RZV...?
Looks as though the openings are larger in the TZR reeds with same bolt pattern as the RZV/RZ/RD500
TZR50
RZV500R
TZR50
RZV500R
73 TM/TS400
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
21 Aprilia RSV4 1100
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
I think the TSI mods would achieve similar results.
Been rather busy and not on site but you are still stuck with the ridiculous 90 turn into the engine. A lot of cutting on a good engine for a one horsepower. I have TDR reed and appreciate the mid range torque.
TDR as in TDR250 stock cages and reeds?
Or is there a company called TDR?
I just searched....there is a company called TDR...
https://shop.bansheedepot.com/TDR-Reeds ... m?page=all
73 TM/TS400
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
I believe they are Tony Doukas. That is the sight. They run well on my track bike.
I'm running the TDR reeds sold for the RD400. They are single pedal reeds that allow the removal of the center rib on each side. My cages look like the ones Ron57 posted earlier in this thread.
Not sure which ones they are. I just had the reed block off and they looked normal besides being composite. Sorry i can not be more help. My engine is stock except for modified carbs, tripod filter, Zeeltronic controller set at GE specs, and Jolly pipes. I get near 90 HP out of it. I want mid range torque and would be nice to have extra power to stay up with the liter bikes in a straight line. The mid range torque allows me to have better exit speed on corners.
hello paul just curious are you using the stock carbs with Ricks mods to them and the size of jetting now with the modifies carbs , filters and exhaust ... all the bestpstamper wrote: ↑Mon Mar 11, 2019 9:25 pm Not sure which ones they are. I just had the reed block off and they looked normal besides being composite. Sorry i can not be more help. My engine is stock except for modified carbs, tripod filter, Zeeltronic controller set at GE specs, and Jolly pipes. I get near 90 HP out of it. I want mid range torque and would be nice to have extra power to stay up with the liter bikes in a straight line. The mid range torque allows me to have better exit speed on corners.
Has some internal mods that I can not explain. I never remove his air jets because they work as installed. Have his tripod filters. Running 290 mains with 35 pilots. Have Ivans needles. Think I am settling at two clips from bottom.
YZ85 V-Force reeds will flow more air than std and even TDR reeds. My ported engine have 0,8 mm. squish, std carbs With std jetting, std elephant ears, std airbox With rubber inlets and std air filter, std 47X cdi, standard 47x exhaust, and zeeltronic PV Controller. 86,6 rear Wheel HP. The Zeeltronic PV Controller is recently fitted, have not experimented With it yet. Stored 1. curve for above tune and 2, curve for above tune, but With Jollys.
I was wery impressed by the Zeeltronic PV Controller and handheld programmer, so I have also bougth the PCDI 24. Havent installed it yet, but the Jollys is put on the bike. Saves 14 kgs and now it really flies. The best is that no midrange is lost compared to std exhaust, and surprisingly enough fuel consumption is same or slightly better. Cant wait to get it on a dyno and play With the settings.
ESW Rotax 250 racer, Kawasaki S2 350,
Yamaha RZV500R, Honda VFR400R. NSU Prima D 150 cc 1957
Have you run on the dyno yet?
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Yamaha AS3 125cc 1978
Yamaha AS1 125cc 1979
Honda CX500
Honda MT125cc 1980
Yamaha TZ125G 1981-82
Zeger TC500cc 1983-84
Yamaha RD500LC 1985-87
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
No sorry
To many Projects at one time. The Zeeltronic PCID24 is still laying on the shelf. Maybe Next year
