Shifting revision
Sub forum for RG400/RG500 owners and enthusiasts
suzsmokeyallan
Shifting revision
#1 Post by suzsmokeyallan » Sat Mar 25, 2017 10:09 pm
There are a few options available to you if you dont like the footpeg to shift lever distance on the stock setup. Theres actually three shift arms that look almost identical, one for the Gamma, one for the Slabside Gixxer and one for the GSX600.
I found the Gamma one was a bit too close to the footpeg for me so heres a solution. A GSX600 lever on the Gamma; its a tad shorter from pivot to rubber and the linkage arm is a tad shorter as well so it will shift quicker with less movement required.
These come with linkage heim joints and boots but this one the heim was bad on the lever section so I cut it off, and drilled the hole out for the Gamma linkage pin. I also have one with perfect heim joints I will try once I've cleaned it up, the small arm on the 600 linkage is aluminum and shorter than the Gamma arm so that will quicken shift effort some more.
The list:
68 Suzuki U70
69 Suzuki T500 MKII
72 Suzuki GT750
74 Suzuki GT750
75 Suzuki GT750
75 Suzuki RE5
76 Suzuki GT750
76 Suzuki TS400
81 Suzuki GSX1100
86 Suzuki RG500 x2
88 Honda CR500
92 Honda CBR900RR
98 Suzuki GSF1200 x3
15 Kawasaki Ninja H2
MarcoM
Re: Shifting revision
#2 Post by MarcoM » Wed Aug 03, 2022 7:28 pm
Old Post but interesting.... Thanks suzsmokeyallan!
Any ideas on how to mod in upside down shift?
MarcoM
#3 Post by MarcoM » Wed Aug 03, 2022 7:28 pm
steveho
#4 Post by steveho » Fri Aug 05, 2022 2:49 pm
To reverse the shift pattern to a ‘race’ configuration, either 1 of the protruding arms (currently at 1 o’clock), needs to be diametrically opposite.
Probably more room to do this with the gear lever itself, as more space available.
Good luck!
