NS400R on display.
Sub forum for NS400R owners and enthusiasts
Re: NS400R on display.
#16 Post by silverstrom » Sun Oct 30, 2016 11:21 pm
Smoker wrote:
Anyone have a CAD drawing, or photos, or just dimensions, for the ATAC chamber expanders? I'd like to try a set.
This is easier http://www.classicracereplicas.com/Hond ... acer-Packs" onclick="window.open(this.href);return false;
It isn't likely there are any proprietary rights to his spacers as it isn't exactly new technology. It is the same principle as reed block spacers. If you want to make your own use a new gasket and trace the dimensions.
#17 Post by Smoker » Tue Nov 01, 2016 4:31 am
silverstrom wrote:This is easier http://www.classicracereplicas.com/Hond ... acer-Packs" onclick="window.open(this.href);return false;
Cool. And I wouldn't be selling them, just for my own use. You're talking about an OEM ATAC chamber gasket, right?
But, I don't understand. Why 3 or 4 spacers? If you have a stock engine, would you use 1, and with more engine mods 2, and with lots of mods 3, and big bore 4?
2002tiil said 3-4 spacers (per cylinder). 12 spacers would use 15 gaskets. Seems like a lot of unecessary risk for air leaks. Why not use one spacer (per cylinder) of the correct length? That's 3 spacers and 6 gaskets, just one extra gasket per cylinder.
#18 Post by silverstrom » Tue Nov 01, 2016 1:13 pm
Remember, there is no ATAC on the upper cylinder.
Speed Freak
#19 Post by Speed Freak » Tue Nov 01, 2016 6:35 pm
:smt005
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
podman
#20 Post by podman » Tue Nov 01, 2016 7:19 pm
My friend Rothmans NS and my 350LC just outside St Tropez on the coast road in the South of France last year, the light down there makes the blue paintwork appear even more vibrant.Not the best of pics to show it mind!
[url]Image
2002tiil
#21 Post by 2002tiil » Wed Nov 02, 2016 10:39 am
I used 3 pieces for the extra volume of the ATAC chamber for front cilinders. That'll be ca 4 - 5 cm's, but you could allso CNC one piece in that form. JCA (pipe builders, correct me if the name is wrong) had them also, ATAC expanders they were called .
My pipes are standard ones, if you go with Jolly's i've seen on a NS, ATAC's needed to be removed.
2002tiil
#22 Post by 2002tiil » Wed Nov 02, 2016 11:45 am
Speed freak, gratuliere mit dein NS400R, Toll! :smt023
#23 Post by silverstrom » Wed Nov 02, 2016 12:42 pm
2002tiil wrote: My pipes are standard ones, if you go with Jolly's i've seen on a NS, ATAC's needed to be removed.
Exactly. For those that don't know, ATAC chambers are only used with stock pipes. If you use aftermarket pipes the ATAC chambers are removed, so spacers aren't an option.
Speed Freak
#24 Post by Speed Freak » Wed Nov 02, 2016 1:04 pm
2002tiil wrote:Speed freak, gratuliere mit dein NS400R, Toll! :smt023
Some infos:
- 62000km, original engine in parts with damaged crankshaft main bearing. But disassembled early enough, no damage on the cases.
Cylinders in perfect condition, only some parts of the bearing cage left 3-4 dents in the center cylinder head.
=> If there is time I have a second engine to rebuild with the correct engine number.
- Engine with 28000km mounted (never opened) which runs quite smooth, but I will pressure test it and check everything before using it.
I don`t really trust the old seals.
- Bike itself comes with complete history (even the purchase bill from 1988 is there), up to 34000km it was serviced by Honda, and afterwards every bill is available.
- Condition: Light crash on the right side (rashes painted by hand), stickers on the lower fairings are new, rest is original.
On the left side it fell down because the side stand snaps up automatically when you just touch the bike.
Stupid design, I think it was required for registration in Europe (today`s standard are side stand switches).
Fairing looks OK, but I need to take it off to see how many little brakcets and holders are snapped off/repaired.
Overall condition of the bike is acceptable without a need to restore the bike.
All in all it`s a good bike to use it instead of putting it into the living room.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
two-stroke-brit
#25 Post by two-stroke-brit » Thu Nov 03, 2016 8:13 pm
lovely bikes all of them.
#26 Post by Smoker » Sat Nov 05, 2016 12:46 pm
That would be me. :mrgreen:
I have Lomas pipes, and don't know shit about the NS400R. Now need to look into removing the ATAC chambers. Didn't even know there's no ATAC on the top cylinder.
Still not sure I'll be keeping the NS400R, but I do love it. For me, it needs to be geared down quite a bit. Hope it's as easy as adding a larger rear sprocket.
Speed Freak
#27 Post by Speed Freak » Sat Nov 05, 2016 2:08 pm
Does anybody know where I get a sticker set for the bike?
Checked the fairing today and only the lower fairing is in bad condition (paint).
It`s not broken, just some scratches.
I can do the white Rothmans Honda sticker on my plotter, but not the printed stripe...
At least the upper Rothmans logo (good replica) and the white stickers on the lower Fairing are not original on mine.
I have checked a lot of Pictures in Google and found many different versions of the Rothmans Honda Sticker.
Can anyone give me a picture of the original paint?
And what is the difference between my front fender and the front fender on the pictures?
Different version (country)?
I have to learn a lot about this bike :mrgreen:
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
#28 Post by silverstrom » Sat Nov 05, 2016 2:36 pm
That looks like the Japanese market front fender. Other markets got a separate fender and 2 fork covers.
RG500.com used to sell complete decal sets. That website is down now and will eventually come back up in a new format.
Check this out http://www.ebay.co.uk/itm/HONDA-NS400R- ... OkuGzHAF0g" onclick="window.open(this.href);return false;
RC45
#29 Post by RC45 » Sun Nov 06, 2016 10:34 pm
The Japanese market removable skirt fender is the same as the rest of the world - I believe that is a 1 piece aftermarket fender.
CBR1000RR SP2 HRC WSBK
TZ500V/OW53 Track bike
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
TZR250 3MA Track Bike
427ci C5 Z07
#30 Post by silverstrom » Sun Nov 06, 2016 10:57 pm
You're right, I missed that. The top photo is aftermarket. The other is stock Jap market.
