RZ500 and RZV500 restore and rebuild
tacky1
#1 Post by tacky1 » Thu Dec 24, 2015 3:03 am
I bought two bikes, 2 RZ500's, One in a box, completely dismembered, the other one a roller with brand new Black/Red complete bodywork kit, Toomeys etc, It runs, badly.
Soooooooo, I have just finished rebuilding the motor out of the box, I oped up all the ports and to a tweaked TSI spec, fitted Vforce3 reeds, 28mm carbs, Heads were already machined down and squish and domes are all reworked.
This is what I bought... :)
tacky1
Re: RZ500 and RZV500 restore and rebuild
#2 Post by tacky1 » Thu Dec 24, 2015 3:08 am
The seller also had this frame, So I ended up buying it from him..
tacky1
#3 Post by tacky1 » Thu Dec 24, 2015 3:11 am
It came with a crap load of new seals, gaskets bolts washer etc. Plus I spent over a Grand at Megazip and bought everything else that was need to finish both bikes with all new nuts, bolts etc.
tacky1
#4 Post by tacky1 » Thu Dec 24, 2015 3:18 am
Engine number one all cleaned up and washed ready for paint
tacky1
#5 Post by tacky1 » Thu Dec 24, 2015 3:19 am
And painted.. :)
Cases and heads are gloss, The main cases and barrels are semi gloss, Primed, paint and clear
tacky1
#6 Post by tacky1 » Thu Dec 24, 2015 3:23 am
Cranks were rebuilt and welded by Crank Works in AZ, I have got most of my cranks rebuilt with them, good guys.
Rebored cylinders by engine dynamics in petaluma
tacky1
#7 Post by tacky1 » Thu Dec 24, 2015 3:23 am
All ready to build
tacky1
#8 Post by tacky1 » Thu Dec 24, 2015 3:25 am
Cases together
tacky1
#9 Post by tacky1 » Thu Dec 24, 2015 3:27 am
Stock and TSI timing, I decided to run the balance shaft off the rear crank and left out the anti lash gears.
Stock timing
TSI timing
tacky1
#10 Post by tacky1 » Thu Dec 24, 2015 3:32 am
And done, That was the easy part, Now the part where I have to strip and redo the frames, all bearings, seals, tires etc, The RZV frame is going to be 100% stock rebuild, The RZ will be on 2008 R6 suspension, Ohlins shock, Front forks have race tech springs and 15w oil, Toomeys and this motor, It will have the Red/Black bodywork.
tacky1
#11 Post by tacky1 » Thu Dec 24, 2015 3:34 am
I also have a 4 degree key in there..
Stock exhaust VS modded port
tacky1
#12 Post by tacky1 » Thu Dec 24, 2015 3:35 am
That's it, That's as far as I have got so far.. :)
#13 Post by Smoker » Thu Dec 24, 2015 6:14 am
Very nice work.
Have you had previous experience with RZ500s?
Vin
#14 Post by Vin » Thu Dec 24, 2015 7:34 am
Great work and update tacky1 :cool:
rd84
#15 Post by rd84 » Thu Dec 24, 2015 8:52 am
Nice work and thanks for showing the progress on your project - always useful and inspiring to see.
