Plastic Repair
Plastic Repair
Bought a product called Plastex and works great. Even comes with a mold to form tabs and parts. Ground out all the cracks on body work and filled in. Grind down good as new. Should have used molding bat on all the tabs but fiqured I would start over for more strength. http://www.plastex.net/" onclick="window.open(this.href);return false;
Re: Plastic Repair
Ground up ABS plastic and acetone. You can make a lifetime's worth yourself for just a few $$.
- two-stroke-brit
Re: Plastic Repair
People over here successfully used this in the past:
http://kulzer-technik.de/en_kt/kt/maerk ... vit_1.aspx" onclick="window.open(this.href);return false;
Check here for the pics of a TDR 250 panel repair:
http://www.rd350lc.de/forum/viewtopic.php?t=22165" onclick="window.open(this.href);return false;
Re: Plastic Repair
That is the same product I am using. Was not that expensive but working great. Next try is to graft a section of the front fairing. Have to figure how to match the cut.
Re: Plastic Repair
Section of broken wind screen that was removed
Section that was transplanted from another fairing
Stitched rear side for extra strength
Missing section of the transplanted piece
Mold from good fairing
Mold taped over missing section
Plastic being molded to fairing
Completed plastic after mold removed
Before sanding new plastic
Repaired fairing ready to wrap
Re: Plastic Repair
Nice work - thanks for showing the technique - hoping I never need it !!
Re: Plastic Repair
If I was a body man I would of painted it. But it is a track bike so will continue with wrap. Thinking of still installing factory decals. Maybe the TZ 250 decals from Alpha Graphics.
- Ronnie
Re: Plastic Repair
Looks a good job. Well done.
Re: Plastic Repair
How did your friends enjoy the TT? You have any local travel agents that might help with setting next years trip up?
Re: Plastic Repair
Heck of a job there Paul. Nice work.
Ken's Garage YouTube Channel
- Ronnie
Re: Plastic Repair
I haven't spoken to them yet but judging by their facebook posts they had a fantastic time. I'll speak to them soon and hopefully they have some information for me I can pass on to you.pstamper wrote:How did your friends enjoy the TT? You have any local travel agents that might help with setting next years trip up?
Did you have a good look throught the IOMTT website? It's full of usefull info.
