RZ500 Street Fighter
Ron57
Re: RZ500 Street Fighter
#16 Post by Ron57 » Sun Nov 23, 2014 12:27 am
Hi All, has been a while still having a few fuel issues.
I cut the centre of the original filter so I could use two separate lines and two fuel taps.
Worked ok, was looking for another way to make it a bit better found out that you can use
a fuel tank tap off a tzr3ma screws on had to do a couple of mods works great.
So far so good, been doing a few other mods billet triple clamps
Post a few more pics later.
Cheers Ron
Ron57
#17 Post by Ron57 » Sat Nov 29, 2014 8:28 am
Hi all changed the rear cowling for one of vin's, still playing with it. I ended up using a billet sprocket carrier. Thanks Rick, couple more pics.
I also did the tsi mods on the reed valves.
Cheers Ron.
mikkell
#18 Post by mikkell » Thu Sep 03, 2015 9:39 pm
hey Ron how is this project coming on....
Jim Bain
#19 Post by Jim Bain » Thu Sep 03, 2015 10:56 pm
Hey Ron, "lookin good" if you need anything give me a shout and ill check my spares or if there is anything else you have my contact info (I.O.U)
Ron57
#20 Post by Ron57 » Sat Sep 05, 2015 6:43 pm
Hi Mikkell, trying to do something a bit different always takes time. Had a few engine issues (rear cylinders) hopefully all sorted now. Had this oil tank made up save pre mixing, just sent the tank off to get a different filler welded in, still working out a paint scheme. Hopefully in a few weeks I'll be back on the road.
Hi Jim that's ok glad I can help out.
Cheers Ron.
Ron57
#21 Post by Ron57 » Sat Sep 19, 2015 9:44 pm
Hi all picked up the paint work, something a bit different.
A few more things to tidy up, then go for a ride.
Cheers Ron.
Ron57
#22 Post by Ron57 » Mon Apr 03, 2017 8:29 am
Hi, has been a while doing some motor upgrades, had Bill Wilson do a phase 3 tune on the motor.
Fantastic work, all together now doing a few heat cycles. Leak down test all good. Mikuni flat slide carbs pain to fit.
#23 Post by Smoker » Mon Apr 03, 2017 7:49 pm
Good to see you're still at it.
Very nice on the engine mods! :smt023
#24 Post by silverstrom » Mon Apr 03, 2017 8:45 pm
Great work. The bike looks amazing.
Can you provide more details for your oil tank? Looks to be a perfect solution.
Watching this with interest as I have been planning a naked 500 as my next project.
Ron57
#25 Post by Ron57 » Sat May 06, 2017 9:59 pm
Hi more updates
Put it all together fuel tank leaked did a tank swap.
Bike is going well, talked to Bill Wilson about going down the EGT path.
Cheers Ron.
mikkell
#26 Post by mikkell » Mon Jun 12, 2017 8:56 am
hi ron ...still at it..watched the youtube dyno clip so many times....sold my 500 a couple of years back...ime tooling around on a chook chaser tdr 250 at the moment...keep at it mate....
Ron57
#27 Post by Ron57 » Sat Jul 08, 2017 3:11 am
Hi looks like the photobucket virus has hit me as well. Latest update on the engine mods
had it on the dyno for a second time made 110 hp to the rear wheel, very happy with it.
Big thankyou to Bill Wilson for his superb engine work and to Borut (zeeltronic) for sending me in the right direction after deleting all the programs. Hopefully we'll find an east way to post
pictures again.
Cheers Ron.
Ron57
#28 Post by Ron57 » Sun Jul 09, 2017 7:26 am
Hi had an offset keyway made up for the rear crank.
just trying image shack thanks RC45
Ron57
#29 Post by Ron57 » Sat Jul 22, 2017 9:00 am
Hi 35mm TMX flat slides, fair bit of work making these fit. I had Bill Wilson make the billet junction
and throttle cables.
Ron57
#30 Post by Ron57 » Sat Jul 22, 2017 9:50 pm
A few shots of the finished bike, maybe.
Hi John this is how the oil tank was made cut into 6 panels then tigged hose connectors are
slip in air lines.
