Operation: MOSQUITO CONTROL BIKE - Florida RZ500 Project (52X)
- TwoStrokeNut
Re: Operation: MOSQUITO CONTROL BIKE - Florida RZ500 Project (52X)
Service M54 - Repack upper silencers...
Okay, I’m back up to recent times with my posts again.
So I thought this next task was going to pretty quick and simple. I was wrong! A frozen silencer added quite a bit of extra time to the project.
The first step was uncovering the top silencers by taking the tank and tail section off, which is a total of 3 fasteners and two quick-disconnect fuel fittings.
Picture 713
Once the silencers are totally exposed the guts could be removed.
Picture 714
The left side slid out with a little persuasion. Yep, it was overdue for a re-pack.
Picture 715
But that’s where the difficulty came in. The right side would not budge no matter what I did. I ended up having to drill out the rivets holding the aluminum housing on, and sliding it off so I could get some penetrating oil in the joint and wiggle it around better. With a ton of effort, it finally broke loose.
Picture 716
Here are the internals, all painted up.
Picture 717
And repacked. I was just winging it… I never read about the proper way to repack a silencer.
Picture 718
Now back in.
Picture 719
Tail section on. I never did care for the fact that the pipe centerline doesn’t match the radius center of the bodywork opening, but fixing that would mean rework to the tail light, mounts and chambers themselves… beyond the scope of Phase 2, for sure. So I will continue to live with it.
Picture 720
Another shot from the side. It looks fine from this angle!
Picture 721
M54 Total Cost: US$0.00 (Paint and packing from inventory)
Picture 713
Picture 714
Picture 715
Picture 716
Picture 717
Picture 718
Now back in.
Picture 719
Picture 720
Picture 721
- TwoStrokeNut
Service C66 - Add redundant fuel shutoff valve...
If you read my RZ350 Revival thread, you can see what damage a failed fuel shutoff can do to a bike. And ever since I read about the TZR250 fuel tank tap being a direct fit for the RZ500 tank, I wanted to install one to serve as a secondary shutoff valve.
Here are a couple shots of part number 3MA-24510-00 as it came out of the box.
Picture 722
Picture 723
Here is a side by side comparison of the OEM RZ500 tap and the TZR tap. I noticed the top lid on the OEM tap was missing and just letting un-strained fuel down into the valve… good time to be replacing it!
Picture 724
Picture 725
The lever is going to stick down quite a bit further and here is a measurement.
Picture 726
Before taking the old fuel tap off, I applied piece of tape representing the distance the lever would stick down. If you look closely, you will see the bottom of the tape folded over about a 1/4” (6mm). This means, realistically, I need to gain 3/8” (10mm) of height to fit this in. I deemed that doable and proceeded with the swap.
Picture 727
Here is the TZR fuel valve mounted on the tank.
Picture 728
With the front tank mount bolt in place by the steering head, I carefully pivoted the tank down into position. With the lever touching the heat shield, you can see the mis-alignment of the rear tank mount. This 1/4” misalign agrees with my crude tape test.
Picture 729
To gain some room, I first added a 1/4” spacer under the rear tank mount.
Picture 730
My tank mount looks different than your because this is my custom spring-loaded version. You can read about it here:
Link - Quick-release on rear fuel tank mount
Its purpose is to keep me from having to remove the long clevis pin that was previously used here. It now takes no tools and I can simple reach down in there and release the locking pins to lift the tank.
Picture 731
I also thought it would be a good idea to add spacer under the side rubbers to better stabilize the tank. It was a bit wobbly before I did this.
Picture 732
To get the last 1/8” (3mm) of clearance, I “tweaked” the heat shield a bit locally in that area. My heat shield already had a flange cut off of it by the previous owner, so I figured another mod would hurt. I simply used a ball peen hammer to persuade it into shape.
Picture 733
Here is the clearance I ended up with after the tank was securely mounted down.
Picture 734
With the small notch designed in this aftermarket tail and seat, its simple to reach down and unlatch the tank mount, and arc the tank up with the front tank bolt still in place. The tank passes through the seat notch nicely, as shown here.
Picture 735
And there is plenty of slack in the fuel lines to adequate lift the tank for operating the new fuel valve. The valve wasn’t cheap, but I’m very happy with the functionality of this modification.
Picture 736
C67 Total Cost: US$100.00 (Fuel tap with shutoff)
Picture 722
Picture 723
Picture 724
Picture 725
Picture 726
Picture 727
Picture 728
Picture 729
Picture 730
Picture 731
Picture 732
Picture 733
Picture 734
Picture 735
Picture 736
I used that tap on my bike.
I just made a different heat shield.
Getting at the lever takes a bit of practice without lifting the tank.
73 TM/TS400
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
21 Aprilia RSV4 1100
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
- TwoStrokeNut
I honestly don't know the arrangement on a stock bike, but on this one with Tommy Crawford chambers and AirTech bodywork, there would be no way to get to it reaching from the underside. I considered making an extension for the valve lever that would let me remote actuate it from an easy-to-reach location, but I'm glad I didn't bother. It is extremely easy to lift the tank and open up the valve.
Another thing I noticed with the two valve system... If I open the tank valve first and pay attention, I can watch some fuel fill the line between the new tank valve and the OEM valve. This tells me the first valve was doing its job (a line completely full might signify a problem). When turning the OEM valve to "PRI", I should then see a bit more fuel trickle from that second valve to fill the carb lines. that tells me the second one is working properly.
I have to drain my tank(again) and check that filter.
It would seem that it can become clogged, but get unclogged with more fuel, contributing to my jetting/carb confusion.
Of course before I luther modded the petcock to give a real "off" it flowed like an sob during removal of lines - now it seems to be at more than a trickle, but insufficient flow to run past 8000. Which it has done in the past with smaller jets but overflowing plug fouling float levels.
Looking forward to being done with fuel issues.
I cut the tip of the lever on both my taps on both my bikes and then you dont have any probs hitting the heat shield or need to make spacers, Didn't make any difference to the twisting motion etc.
Filter fine as previously "demonstrated".
Seems it must be the fuel lines getting kinked . Of course I thought I had the routing with k&n/petcock relocation sorted.
I'd say the luther mod is simpler than a petcock you can't reach.
- TwoStrokeNut
lost1750GTV - Yeah, those fuel issues can be a real pain. Just a thought on the clogged/unclogged filter… maybe the extra fuel in the tank is helping to create a bit more pressure to assist with filling your hoses to the carbs. Check that you have downhill slope in all your lines with the bike upright and leaned some (like on the kickstand).
The stock fuel valve will flow very well, so it shouldn’t be starving for fuel with modded or unmodded version, I wouldn’t think. I just did a flowrate test on my bike with stock valve and I will be sharing the results shortly.
tacky1 - You know I like to take the difficult route when I can. Haha. I just couldn’t bring myself to cutting that brand new (expensive) valve. Maybe I will cut it someday and remove the spacers.
smoker - Glad you approve!
lost1750GTV - again - I didn’t see this until after I wrote my other response, but yes, check those lines!
In my case, I wanted redundancy. And a system where I could check that both were still functioning properly. That large disk seal in the selector valve can crack and fail as easily as the vacuum shutoff can stop functioning. I have 2 valves in all of my gravity feed carbureted bikes now.
- TwoStrokeNut
Service C58 - Replace rear brake line...
I went to ride the RZ500 the other day and my brake pedal went all the way down without applying the rear brake. Did it stop me from taking a little ride to give the bike some exercise… no. But is should have. This bike begs to be ridden hard, but without a rear brake as at least a backup to the front, horrible thoughts flash through my head. Well, a potential wreck final got to me and I ended the ride after just a few miles.
I realized I had never replaced the rear hose like I intended to, so I thought this was a great time to dig into the cause of failure and at the same time, renew that hose. The thought did cross my mind that the hose itself was in fact the cause of the failure.
Before even taking anything apart, I tried a simple fluid flush. Of course that didn’t work because I couldn’t build up any pressure… not even enough to push a little fluid out the bleeder. I suspected a problem in the master cylinder and started by taking that apart. What I found was contamination, and lots of it!
Picture 737
Picture 738
I had this system all apart in 2014 and surely I would have noticed and cleaned out that reservoir hose back then. So this is all from just 7 years, I guess.
What I’m suspecting caused the pedal going full stroke without creating pressure is a plugged port in the master. These holes are tiny and I suppose it wouldn’t take much to clog them.
Picture 739
Picture 740
Here is the old hose, which I suspect was the original.
Picture 741
And here is the new one. I honestly was fine with the look of a black hose, but now this SS version matches the front, so I guess it’s alright. A forum member on here had it for sale at the right time (Thanks!).
Picture 742
One thing cool about these Galfer lines is you can twist each end fitting to align perfectly with the mating port, but it this case, they were already positioned correctly to avoid twist in the hose. It routed perfectly through the guide.
Picture 743
A fill and bleed has the system working nicely again.
Picture 744
Here’s a final shot.
Picture 745
While I was at it, I decided a flush of the front brakes was probably overdue too since I did them at similar times before. And with all the tools/pans out out, it just added 15 minutes to the job.
Picture 746
C58 Total Cost: US$45.00 (Brake hose, fluids from stock)
Picture 737
Picture 738
Picture 739
Picture 740
Picture 741
Picture 742
Picture 743
Picture 744
Picture 745
Picture 746
- TwoStrokeNut
Service C27 - Fuel Flowrate with quick disconnect fittings installed...
For the last 8 or 10 years now, I have used ethanol-free fuel combined with Stabil fuel stabilizer in all my small engines and old vehicles. The last fuel-related issue I have had in anything was with the RZ350, but that was pre-ethanol-free days mixed with a whole bunch of neglect. Even the small hoses on my small engines (mowers, string trimmers, chainsaws, etc.) don’t have to get replaced every two years anymore.
Although Stabil says it works for up to 2 years and even thought the RZ500 was starting and running fine with the old fuel, I realized the fuel in there was much older than that so I decided to drain and replace it. To my defense, I have added a half gallon here and there as it needed it, so some of the fuel is fairly fresh.
Remembering back to when I installed some quick-disconnect fuel fittings from the tank, there was some discussion and concern whether the fuel flow was being restricted in some way. At the time, I wanted to measure this just to set my mind at ease about damaging the engine due to a lean running condition (fuel supply starvation). But it’s better late than never!
Link to prior discussion on flowrate:
http://www.rzrd500.com/500phpBB3/viewto ... 105#p96883
In that reply, it was stated that we are looking for a flowrate greater than XXX. Here is a snip of the recommendations:
This reply came from forum member Wolfgang:
"I usually do the following math to get a ballpark figure, using expected max. peak fuel consumption. My calculation is in ltrs/100km as we do in most part of Europe, you can modify this to mpg of course:
Assumed max. consumption is 20l/100km at a speed of 200km/h.
Within 1 hour, you would drive 200km = 20l * 2, so you would burn 40l of fuel.
Your fuel lines need to flow a min. of 40l/hour.
So put a fuel line into an empty bottle and measure the amount of fuel you get within a minute. If it is min. 40/60 = 0,67l, you should be safe. If it is 1l per minute, you can feel even better."
In all honesty, I feel a steady state one hour calculation is possibly understating the peak fuel usage at any given moment. I would venture that twice that flowrate a might be witnessed during a WOT run up through the gears. Perhaps 1.4 liter/minute range might be a more suitable target to set.
First, I rounded up a portable tank to catch the fuel (I always reuse any drained fuel in the mower because it will happily burn anything!).
Picture 747
Then attached my mating fitting and drain hose to the RESERVE line.
Picture 748
There was less fuel left in there than I thought and I dumped in into a smaller 1 gallon sized container for easier measuring. Even with the backlighting, the fuel level is difficult to see in this picture, but blue tape marks full gallon and actual height of fuel. The rough amount of fuel in the can is therefore 4.188/6.625 = .632 gallons.
Picture 749
While I was draining the fuel, I used a stop watch app to measure time, which recorded 83 seconds.
Picture 750
Doing the math for .632 gallons in 83 seconds works out to:
Fuel Flowrate = 0.457 gpm = 1.73 liter/min.
As I was conducting this test, the speed of the flow indicated it wasn’t going to be a problem (it was flowing fast!), but it’s nice to know the exact number.
After I finished up this little test, I realized I overlooked one small (maybe big?) detail… the tank venting. While I was draining the fuel, I had the cap off the tank. A more thorough test would have had the cap installed to check whether the venting is restricting flow in any way. I guess I will do that another day and at this point, I have the flowrate with tank wide open for comparison.
For now, I can rest assured the fuel line disconnects aren’t an issue.
C27 Total Cost: US$0.00 (Just measurements - Flowrate calcs)
Picture 747
Picture 748
Picture 749
Picture 750
I have regularly determined my flow rate was more than adequate during my petcock, fittings, and float "tests".
Forget to reattach the fuel line connecting the two carbs before turning the petcock on and you are instantly assured the flow rate is more than adequate, and any curiosity is satisfied by the knowledge of the extremely adequate "plenty".
- TwoStrokeNut
LOL. Yes in a panic situation, the flowrate can seem quite excessive!!lost1750GTV wrote: ↑Sun Sep 05, 2021 9:34 am I have regularly determined my flow rate was more than adequate during my petcock, fittings, and float "tests".
- TwoStrokeNut
Service C67 - Reshape foot of Kickstand...
I recently got back into welding again and rigged up a small welding booth for occasional jobs that come along. One thing that has bothered me on this bike since purchasing it in 2012 is the ground down tip of the kickstand, resulting from a previous owners’ unfortunate accident (I’m guessing).
Here is the flat spot in the foot.
Picture 751
And a close up.
Picture 752
Welding was really the only way to fix this. Several beads added the extra material back on.
Picture 753
Then after a little grinding to blend the surfaces, I ended up with this.
Picture 754
After a quick paint.
Picture 755
While it was off, I took the opportunity to pinch the clevis together ever so slightly for a snug fit again on the mount.
Picture 756
And back on the bike.
Picture 757
Picture 758
C67 Total Cost: US$0.00 (Just a little molten metal and paint from inventory)
Picture 751
And a close up.
Picture 752
Picture 753
Picture 754
Picture 755
Picture 756
Picture 757
Picture 758
- TwoStrokeNut
Service M51 - Decide if Rick Lance’s cooling system is acceptable for my needs...
At some point along this bikes life, it spent some time in the hands of the late great Rick Lance and I’m really thankful it did. That guy knew what he was doing. The carburation is spot on and I’m impressed how cleanly it pulls from any RPM with any throttle opening. During my conversation with him after purchasing the bike, I didn’t talk specifically about the supplemental radiator, but I’m guessing that’s when it was installed as well.
As homage to Rick and his contributions to this whole 2-wheeled 2-stroke sport, I decided to keep his supplemental radiator in this bike. Although I have the OEM parts to return the cooling system back to stock state, it seems to be working fine as is, so I see no reason to change it. Plus with an overflow bottle now installed, I know the entire system is completely wetted and operating at its peak performance.
Here are some photos I found on the internet when I was doing the early research on my bike back in 2012. This is not my bike, but the auxiliary radiator is the same.
Picture 759
Picture 760
Picture 761
Picture 762
M51 Total Cost: US$0.00 (The price of “leaving well enough alone”)
Picture 759
Picture 760
Picture 761
Picture 762
