Beefing up the crank & Gearbox in prep for 500cc.
Any ideas?
I want to pursue bumping up the displacement to 500cc and wonder how much of a weak link the crank and gearbox will be.
CBR1000RR SP2 HRC WSBK
TZ500V/OW53 Track bike
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
TZR250 3MA Track Bike
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
Re: Beefing up the crank & Gearbox
The only weak link I can think of in the stock gearbox would be the 2nd gear shift fork. Early bikes were plagued with failures. Lots of blown up gearboxes. The fork was modified on later bikes. There is a casting mark on the modified fork to differentiate it from the early weaker version. If you have an early bike with an unmodified shift fork it could make itself know pretty quickly with a high HP engine.
Talk to Ian at CRR. He would be the authority on a big cylinder NS400R. The biggest I know of is his 475 cc motor. His 475 kit makes 85 RWHP with stock (bored) carbs and Lomas pipes. I don't know if he has modified the clutch, but they are known to be reliable. There isn't much written about cranks being a problem, but you'd be rebuilding it with the best parts available and welding it anyway if you plan to make serious power, and for that motor, 85 is serious.
What is your plan? Something like this
That is a nice looking bike! But U am in love with the 3 cylinder NS500.
I have my eye on a DMR 500cc kit.
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
Hi Hope your well?RC45 wrote:That is a nice looking bike! But U am in love with the 3 cylinder NS500.
Can you give us more information on this kit like the availability - Cost etc?
Ade
That bike is a 3 cylinder. Notice how the upper pipe splits to 2 silencers under the tail. An homage I suspect to the NS500 which had 2 cylinders up and one down. The street bike required an airbox and necessitated the 2 down and one up arrangement to accommodate it.RC45 wrote:That is a nice looking bike! But U am in love with the 3 cylinder NS500.
https://store.shopping.yahoo.co.jp/dmr- ... 00201.html" onclick="window.open(this.href);return false;Ade SYM wrote: Can you give us more information on this kit like the availability - Cost etc?
Oh I know the split upper pipe to fake the V4 layout very well - I know this bike as well. If I wanted to have 4 pipes I could just use an RZ500 motor in a Honda fairingsilverstrom wrote:That bike is a 3 cylinder. Notice how the upper pipe splits to 2 silencers under the tail. An homage I suspect to the NS500 which had 2 cylinders up and one down. The street bike required an airbox and necessitated the 2 down and one up arrangement to accommodate it.RC45 wrote:That is a nice looking bike! But U am in love with the 3 cylinder NS500.
This bike just fakes the V4, the fairing and pipe layout give that away. the "wrong" layout of the NS400 has been the biggest thing for me. I might try to a early Japanese privateer NS400 race bike that used race NS250 bodywork that was really RS250 bodywork.
DMR Japan designed this kit about 7 years ago. It uses new casting cylinders and pistons. Also requires a bit of case machining and NSR250 parts adoption.Ade SYM wrote:Hi Hope your well?RC45 wrote:That is a nice looking bike! But U am in love with the 3 cylinder NS500.
Ade
I have reached out to DMR a couple times over the years - and they don't export at all so I am working through a local contact to determine how much of the kit is in the kit, how much needs to be fabricated from scratch and how much is adopted from existing parts.
Either way this is a complete custom endevour that may take a while
As to cost, the basic kit is about $2500, and then the real work would start.
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
What kind of power can the DMR kit make?
With dry clutch, custom pipes and MC21 PGMII timing 100hp. Closer to 80hp or less with NS400 pipes and stock ignition/timing.silverstrom wrote:What kind of power can the DMR kit make?
The DMR dry clutch kit is a pretty rare setup, that can be yours for the princely sum of $4000... LOL
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
As usual, you have to pay to play. I assume you'd go all in and go for the max. Seeing your other projects you don't do anything just a little bit
Yes - I do seem go off the deep end a little at times LOL
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
Re: Beefing up the crank & Gearbox in prep for 500cc.
Anyone know how much their dry clutch assembly costs?
1985 RZ500
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1985 NS500 Spencer p
1989 TZR500 Biaggi p
1984 RZV500 Rainey p
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
ns86 wrote:Anyone know how much their dry clutch assembly costs?
$4000 to $5000 USD and you still need to source parts and do custom assembly etc. These are not plug and play kits at all. They are simply assemblies some of the hardest to find parts to work towards a particular solution
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
I've liked their stuff for years and also want an NS500 type. A few you tube videos but always hard to find their parts for sale. I am watching closely. Spend on RC45
1985 RZ500
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
Apparently early RS250 engine cases and clutch bits can also serve as a good donor starting point. Rather can cost $5000 the bits are probably rarer than a 27c coin lol.ns86 wrote:I've liked their stuff for years and also want an NS500 type. A few you tube videos but always hard to find their parts for sale. I am watching closely. Spend on RC45
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
