Need Help With Tank Calculation
Smoker
Re: Need Help With Tank Calculation
#76 Post by Smoker » Thu Aug 23, 2018 11:34 am
Looks like the smallest detail is the neck on the "Man".
Anybody have an idea how small that cut could be, or how large it needs to be? Just wondering how small the machine tools are.
The plate is 6Al4V titanium, probably 5mm thick. Depth of cuts would be 3mm. Once I know the machining is possible (mill, CNC, laser, EDM, whatever), I'll order the titanium.
I don't mind paying to get the CAD drawing done. Should be able to find someone that does it for a living.
Jeff B
#77 Post by Jeff B » Fri Aug 24, 2018 2:20 pm
Here's what I'd use to rough it.
https://www.kyocera-sgstool.com/uploads ... ARB_AP.pdf" onclick="window.open(this.href);return false;
MK
#78 Post by MK » Sun Aug 26, 2018 3:08 pm
How about asking at a jewlery or maybe electronics company for PCB's about etching the plate?
Smoker
#79 Post by Smoker » Sat Sep 01, 2018 10:40 am
Sent an email to the laser cutting company.
They apologized and said they forgot about my project.
Fuck me. Never get a break.
Finally spoke to the laser machinist. More bad news. He said the machine uses 15 inches of the tube to hold it. Great. I sent 2 titanium tubes, 36 inches each. Looks like half the tubing will be unusable, and I'll need to buy more.
Waiting to see exactly how many pieces he can cut from the 2 tubes.
MK
#80 Post by MK » Sat Sep 01, 2018 3:04 pm
What if they just machine a 15 inch long Al bar to match the inner diameter of the Ti tube and use a hose clamp to fix it on the bar?
Laser cutting does not need a tight fixture.
Jeff B
#81 Post by Jeff B » Sat Sep 01, 2018 7:20 pm
MK wrote:What if they just machine a 15 inch long Al bar to match the inner diameter of the Ti tube and use a hose clamp to fix it on the bar?
I agree that there must be a way to waste less than 15"! I suppose they normally cut cheap material that comes in long lengths where being wasteful is more cost effective.
Heck, you could weld the two 15" pieces together. Then your down to little more than 15" of waste.
Smoker
#82 Post by Smoker » Sun Sep 02, 2018 1:12 am
There's definitely a way to reduce the amount of wasted titanium.
Just don't think the laser cutting company could give a shit about my less than $300 usd order.
Even more work on their part, to save a few hundred for the customer? I don't think so.
I'll suggest you're ideas, and thanks for trying to help me save some cash.
Should hear something soon.
Smoker
#83 Post by Smoker » Sun Sep 02, 2018 8:25 am
Would have been nice if they mentioned the 15 inch clamping requirement before now! :mrgreen:
Smoker
#84 Post by Smoker » Wed Sep 05, 2018 12:14 pm
I was told, the laser company would give me a call when they figured out how many pieces they could get from my titanium tubing.
Just got the call. Pieces are done. Somehow, they got all 16 pieces I asked for.
Hope my calculations are okay, and their cutting is accurate.
Going in person to pick up the parts today. Will ask about cutting the titanium plaques.
#85 Post by silverstrom » Wed Sep 05, 2018 3:07 pm
Progress...at last! I'm hoping your luck has changed and this can be done quickly.
Smoker
#86 Post by Smoker » Thu Sep 06, 2018 8:23 am
silverstrom wrote:Progress...at last! I'm hoping your luck has changed and this can be done quickly.
I appreciate the sentiment, but no....
Paid $280 for the titanium and $225 for the laser cutting.
Short side of each piece should be close to 35.19mm. All pieces too long. Most are 36.48 - 36.72mm.
Long side should be close to 75.92mm. All pieces too short. Range from 74.98 - 75.79mm
Cut angle should be 15 degrees. All but one are 14.5 degrees. One side of one piece is 15.5 degrees.
Knew it was bad right away. 6 pieces should make a half circle.
MK
#87 Post by MK » Thu Sep 06, 2018 12:40 pm
F...k.
That was an expensive experience!
How about sending the pieces "as is"?
I'd give it a try on a flat grinder which is done all the time to match single pipe segments.
You can also slightly rotate the pieces to get a slightly different angle.
Smoker
#88 Post by Smoker » Fri Sep 07, 2018 12:35 pm
Thanks for your support, Martin! :smt006
Things are getting more difficult as time passes. Trying my best to continue on with the projects and stay positive. Still unsure if this, or other projects, can be completed. All my projects are built on the fly, without much planning, and things change a lot as I go. It's fun, but makes it harder to finish.
I sent the laser company measurements from the pieces they cut, and didn't ask for anything. Got an email back saying their standard tolerance for cutting is 0.01 inch. They weren't anywhere close to that with my stuff. Evidently, the problem was having to common line cut the pieces [because of limited tubing]. "We need to space them out and lead in to the cuts". They offered me a refund or recut.
So, I could use these parts and get my money back. :smt003
Not my style, though. I'll buy more titanium and hope they get it right. Will need to buy more titanium than last time. Waiting for the laser company to tell me how much tubing they need.
Jeff B
#89 Post by Jeff B » Fri Sep 07, 2018 2:21 pm
Did you tell them what the tubing cost you?
Smoker
#90 Post by Smoker » Sun Sep 09, 2018 11:06 am
Jeff B wrote:Did you tell them what the tubing cost you?
Yep.
I don't expect to get that money back. :smt102
