RZ500 Street Fighter
Re: RZ500 Street Fighter
Thank you. I appreciate the information.
The bike looks great. The timing is perfect. Just yesterday I was thinking about black and silver and wondering how it would look with a black frame.
Hi here is a photo of Bill's reed mod, hope you don't mind Bill and the spacer to get the clearance
between the two carbs. there is still a lot of work making these fit.
These are the curves Borut sent me, hope this is ok as well.
Cheers Ron.
Cheers Ron.
HI Ron,
great bike and 110 Hp to the rear wheel is a great power.
Do you have somes pics of the tuning manifolds ?
What is the setting of your TMX ?
Regards Nick
Regards Nick
Hi, Bill Wilson opens the rubber manifolds to match the modified reed valves.
The 35mm tmx carbs are jetted for 125 motocross bikes and that jetting is very close
to what I am using.
Cheers Ron.
to what I am using.
Cheers Ron.
Hi Ron,
when you have wrotten ''Bill Wilson opens the rubber manifolds'' you are talking about the inlet, outlet or both?
regards
regards
Hi The rubber manifolds are matched to the reed valves, also opened up on the inside.
When using 35mm carbs you have to grind about 1mm on the inside of the rubber manifold to be flush.
It's a fine line getting it right, That's why I'll be getting Bill to do my next set.
Cheers Ron.
Cheers Ron.
does rz500 use gasket between manifold and reed from factory?
Hi, the only gasket is between the reed and barrel, I've been using Three Bond between the
rubber manifold and the reed.
Cheers Ron.
Cheers Ron.
Ron57 wrote:Hi all, building something a bit more up rite so us oldies can ride (me).
Have had a lot off help from forum members again. Thanks
Gus's cranks
Bill Wilson bracket and throttle kit
Been on going for a while siowly getting there here it is on the dyno
http://www.youtube.com/watch?v=gA2aAVnkS6Y" onclick="window.open(this.href);return false;
Cheers Ron
Ron57 wrote:Thanks Bill and Rich, good to here u like it.
Hi Donald Duck made 83.5 at 10,600 revs
Thanks.
Cheers Ron
Ron57 wrote:Hi all, Jetting on the dyno was 40 pilot, napf needle, 138 main was running lean qauter to half
throttle so went next richer needle napg. Had 20 percent lighter throttle springs made. Haven't
had a chance to run it yet. Throttle is a lot lighter.
RGV forks had them lentghend 25 mm get the front up a bit more
nitron rear shock stanard petty no ride height adjuster
Back end so far
Hope you enjoy the progress.
Cheers Ron
Thanks Mate,
Cheers Ron.
Cheers Ron.
Ron57 wrote:Hi All, has been a while still having a few fuel issues.
I cut the centre of the original filter so I could use two separate lines and two fuel taps.
Worked ok, was looking for another way to make it a bit better found out that you can use
a fuel tank tap off a tzr3ma screws on had to do a couple of mods works great.
So far so good, been doing a few other mods billet triple clamps
Post a few more pics later.
Cheers Ron
Ron57 wrote:Hi all changed the rear cowling for one of vin's, still playing with it. I ended up using a billet sprocket carrier. Thanks Rick, couple more pics.
I also did the tsi mods on the reed valves.
Cheers Ron.
Ron57 wrote:Hi Mikkell, trying to do something a bit different always takes time. Had a few engine issues (rear cylinders) hopefully all sorted now. Had this oil tank made up save pre mixing, just sent the tank off to get a different filler welded in, still working out a paint scheme. Hopefully in a few weeks I'll be back on the road.
Hi Jim that's ok glad I can help out.
Cheers Ron.
