93311 42056 and 93311 92557 gearbox bearings
geosot
#1 Post by geosot » Sat Oct 20, 2007 1:46 pm
I have found a ball bearing and a needle roller bearing replacing the above.
Ball bearing has dimensions
25 ID 47 OD
and needle roller bearing has dimensions
20 ID 35 OD
Both have inner rings and they are direct replacement for the OEM parts that are NLA from Yamaha.
George
gus
#2 Post by gus » Sat Oct 20, 2007 5:51 pm
George, glad you posted that I'm leaving monday morning to head back over I'll do the other stuff on my list and scratch the bearings off the list thanks
geosot
#3 Post by geosot » Sun Oct 21, 2007 2:51 am
gus wrote:George, glad you posted that I'm leaving monday morning to head back over I'll do the other stuff on my list and scratch the bearings off the list thanks
The bearings I found are not the same as the OEM. They have the same dimensions but they are of a different type.
If you could find the OEM I can always get a pair or more.
George
lcjonny
Bearings
#4 Post by lcjonny » Sun Oct 21, 2007 5:01 pm
Are these the main crank bearings. Not sure if its the same as my old 4lo mains but my local dealer has said the bearings are of a different clearance class as normal bearings to account for the added heat generated by the engine. They are graded as C3 or C4 bearings (cant remember which)
Dont know how true this is but it may be something to think about before using normal bearings in the engine.
Jon
geosot
Re: Bearings
#5 Post by geosot » Sun Oct 21, 2007 5:34 pm
lcjonny wrote:Are these the main crank bearings. Not sure if its the same as my old 4lo mains but my local dealer has said the bearings are of a different clearance class as normal bearings to account for the added heat generated by the engine. They are graded as C3 or C4 bearings (cant remember which)
Jon
They are not the crank bearings. The crank bearings are rated C3. Normlly you can find the crank bearings in your local bearing shop. If you need further info on the crank bearings let me know.
George
PaulGreen
#6 Post by PaulGreen » Wed Jul 13, 2011 4:33 pm
Hi George,
I know this is raking up avery old post but I'm looking for both of these part numbers.
Are they still available?
Thanks,
Paul.
PS - Just to clarify, aren't both of these parts needle bearings?
john larsen
Re: 93311 42056 and 93311 92557 gearbox bearings
#7 Post by john larsen » Wed Oct 11, 2017 2:58 pm
geosot wrote:I have found a ball bearing and a needle roller bearing replacing the above.
25 ID 47 OD
20 ID 35 OD
George
Hi George -would i be possible that you have the part numbers for the replacement bearings you have found. Your assistence will be highly appriciated - Rgds John
#8 Post by silverstrom » Wed Oct 11, 2017 3:41 pm
You'll find them at the link below
http://www.ebay.ca/itm/RZ500-RD500-RZV5 ... Oj&vxp=mtr" onclick="window.open(this.href);return false;
