I have swapped the coils
and it done the same thing
I will put a message on the forum to see if I can send cdi to someone to check for me
if I cant find one and it is that can I buy the spare one of you?
cheers
stator or not
Re: stator or not
allways look on the bright side of life
LMAO
LMAO
Re: stator or not
We can discuss it if needed. Hopefully you'll find a way to test yours so you can know for sure.500.FLETCH wrote: ↑Tue Apr 07, 2020 3:23 pm
cheers
Re: stator or not
What exactly did you swap?
Hopefully you mounted the upper coil to the lower cylinders and vice versa?
If yes and the issue persists, then swap the orange wires on the lower/upper coil primary side. You'll need to manufacture two extra cables to extend the stock ones.
Or simply insert two bullet connectors into the orange cables between CDI and CDI plug. In that case you can swap very easily.
If you swap cables and the effects changes location, too, then that's hard evidence for the CDI being faulty.
Re: stator or not
What exactly did you swap? coils leads and caps only?
Hopefully you mounted the upper coil to the lower cylinders and vice versa? wtf can this be done?
LMAO
LMAO
