Where to start - putting it back on the road
Wiring loom - before...
During....
And after....
Not perfect, but better than it was.
I'm curious about something though. All of the through crimps in the loom were wrapped in insulation tape making them a proper gooey mess. Is this how they left the factory? I know it's not recommended to use insulation tape for this.
Cheers,
Paul.
During....
And after....
Cheers,
Paul.
Is the larger earth cable necessary or were you just being cautious? I thought there were ample earthing points around the bike, I'm always willing to take advice though.
Where I broke into the loom I've used heat shrink crimps, the joints which were good have just been wrapped in self amalgamating tape. Some of the sublooms (?) have been wrapped in loom tape where appropriate.
I've just fitted the loom and switched the ignition on to the glorious sound of the powervalve servo bursting into life, still waiting for pv cables though (over a month now) so it got a bit confused! Lights and horn etc all seem to be working ok.
I've managed to get all silencers off and both upper exhausts need welding at the mounting points.
After that it's just the minor issue of splitting the carbs and removing all of those seized phillips screws!
Cheers,
Paul.
Cheers,
Paul.
Hi,
So I'm back on to the exhausts, i Want to remove 40,000 miles of carbon from them. I was planning doing it the old school method with the oxyacetylene torch....
http://www.youtube.com/watch?v=R_J7sADP ... re=related
I'll probably be a little less "gung-ho", maybe even wear some long sleeves!
Has anybody done this? Does it give good results?
I'm concerned about doing the upper exhausts because I can't see any way of replacing the baffle material - assuming there's some in there?
And, to replace the baffles in the lower exhausts is it just a case of drilling out the rivets at the ends of the silencers?
Any advice is appreciated.
Cheers,
Paul.
Cheers,
Paul.
Awesome project sir.
If i do the pipes like that i know the cops will show up, i always do it with riding it hard.
Today i did melt my chainguard, when i did stop the smell was alarming.
And that's all I have to say about that.
http://www.youtube.com/watch?v=vG8UJZzYHDs" onclick="window.open(this.href);return false;
http://www.youtube.com/watch?v=yHFsoHd0nZI" onclick="window.open(this.href);return false;
http://www.youtube.com/watch?v=JJ5pCjnMQQg" onclick="window.open(this.href);return false;
http://www.youtube.com/watch?v=OyZfNKHPRs8" onclick="window.open(this.href);return false;
Hi Paul,
In the 1980's caustic soda was the favoured method of cleaning two stroke exhausts out - You would bung one end up and pour the solution in and leave it for several days. It might take two or three applications. However you must leave the pipes in a safe well ventilated place away from animals and children and you must wear googles and protective clothing - if you get it in your clothing or on your skin wash with lots of water immediately - as a minimum wear latex gloves and goggles. If you can't get it from a supermarket try an hardware store or the chemist.
BTW in the 1980's we didn't wear any safety equipment - we were just careful !
Also of interest - I've used quality two stroke oils since I bought my bike in 1984 and it still doesn't need a de-coke - just nice dry thin grey deposit inside the system - amazing when I think back to my RD400 whose exhausts and ports were full of black oily carbon.
Do be careful if you use caustic soda though - it can get hot and spit a bit - but if you're sensible there is no reason not to use it.
I think you'll need to keep the soda away from the alloy silencers - perhaps you could experiment with some scrap aluminium to see what happens ? - I would suggest you try asking on the forum for further advice on this.
PaulGreen wrote:Hi,
Cheers,
Paul.
Hi,
So I was browsing the eBay forum and noticed a reference to barrysheeisgod's carbs on his ebay listing looking "MINT".
Well, I've used half a dozen toothbrushes and 4 tubes of Autosol on my carbs and was quite pleased with myself.
This is what they looked like before I started:
And then I saw barrysheenisgod's.
I looked into this vapour blasting lark and found that there's a local bike shop that does it - about a mile from my house. I went to see them on Monday. Stripped the carbs down and dropped them off on Tuesday and got a call at 3 o'clock this afternoon to say they've been vapour blasted and ultrasonically cleaned and were ready to pick up.
They even removed a small pan head screw that was seized in - really can't fault the service.
I'm £160 lighter but now I'm the proud owner of these!
Cheers,
Paul.
Cheers,
Paul.
I know I'm a bit late on this, but definitely keep caustic away from ally. It will etch into it.
I dipped my ally parts into caustic soda before anodising them because it cleans the surface and opens the pores for the ink to set in.
http://www.mustangtech.com.au/Content/p ... pid=7.html
Chris Gunster (http://www.chrisgunster.co.uk/) in Grimsby did mine if you're interested.
I think it was well worth the money.
Cheers,
Paul.
Cheers,
Paul.
