kpke RZ500 resto/mod
Vin
Re: kpke RZ500 resto/mod
#196 Post by Vin » Tue Feb 09, 2016 3:32 pm
Very nice job :supz:
kpke
#197 Post by kpke » Wed Feb 10, 2016 1:41 am
Thanks Vin! Coming from a master builder such as yourself that means alot.
Removed all silencers and cleaned out rivets with Brakleen. Plugged all the rivet holes with JB Weld. Need to make new closed cell foam gaskets and reinstall tomorrow. I hope this works.
two-stroke-brit
#198 Post by two-stroke-brit » Wed Feb 10, 2016 3:11 pm
hey Ken , have you ever weighed your bike ?.
thanks mark
kpke
#199 Post by kpke » Thu Feb 11, 2016 11:06 am
No Mark. I have not weighed the bike.
The JB weld in the rivet holes worked. Now I am down to 1 silencer leaking in a different spot. :smt013
kpke
#200 Post by kpke » Sat Feb 20, 2016 10:04 pm
Installed Venhill front brake lines (to match the rear).
2005-2014 Yamaha R6 Twinline Front Kitp
pstamper
#201 Post by pstamper » Sun Feb 21, 2016 10:50 am
How are you brake lines routed. Behind fork or front.
kpke
#202 Post by kpke » Mon Feb 22, 2016 11:47 am
The lines route in front of the lower triple clamp. Just like the original rubber lines.
I utilized the tapped hole where the original Y was mounted to for two separate clamps for each brake line.
kpke
#203 Post by kpke » Sun May 22, 2016 7:18 pm
New blue wheels (and Q2s)
Today at The Junction
Back to Livermore
tacky1
#204 Post by tacky1 » Sun May 22, 2016 9:03 pm
Ken, They look fantastic on the bike, Really make it pop, Perfect match,
Jeff B
#205 Post by Jeff B » Sat May 28, 2016 3:59 pm
I love the bike! Are you going to add any stickers like "RZV500R" or something similar?
#206 Post by silverstrom » Sat May 28, 2016 10:29 pm
Jeff B wrote: Are you going to add any stickers like "RZV500R" or something similar?
Decals? Really? Gawd..I hope not.
Jeff B
#207 Post by Jeff B » Sat May 28, 2016 11:19 pm
Don't get me wrong. I'm just being curious. I think it looks great as it is as well.
kpke
#208 Post by kpke » Sun May 29, 2016 10:22 pm
Thanks Jeff B
A good friend of mine is an Industrial Design Engineer. I asked him about putting decals on it.
He seemed to think I should.
But for now no. I kind of like the mystery of the bike not having any indication of what it is other than the gold tuning forks on the tank. I guess and Yamaha on the engine cases.
From yesterday Hmmm need to go to the other computer to load pics. My laptop just can't do photobucket anymore.
kpke
#209 Post by kpke » Sun May 29, 2016 10:46 pm
Yesterday installed a clear plexi panel inside the lower front fairings to protect the engine from getting gravel blasted from the not so perfect Mines Road. When it gets too beat up I will paint the back of it black.
The radiator fan was doing mysterious things, turning on when the bike was switched on not started and cold, not consistently coming on when the bike is hot. So today I installed a manual switch for the radiator fan. I had an extra slot in the 5 position fuse block so it was utilized to fuse the fan. A 10 amp fuse is being used. 5 amp instantly vaporized. Same setup as on one of the RZ350’s with an R6 fan installed.
rzbill
#210 Post by rzbill » Sat Jun 17, 2017 1:39 pm
kpke wrote: 6 Air filters have deteriorated and need replacement. Options are
A. UNI will make new ones to their PN PT-2642 $21.99 each
I just started a conversation with Uni about replacing my Mad Beaver Uni's.
Hopefully they will still make them at a price similar to above.
I'll post the results for the group when I know.
Regards,
Bill Pendergrass
Bill Pendergrass
'84 RZ500N Modified
'73 R60/5 Also Modified
RV7A Completed in 2012 and flying well.
http://websites.expercraft.com/rzbill/" onclick="window.open(this.href);return false;
