Work in progress
theredbarron
Work in progress
#1 Post by theredbarron » Fri Dec 21, 2018 4:17 pm
Here are some pictures of our work in progress. Some of the parts have been a real labour of love to manufacture / install, the Yamaha FZ600 front wheel into the GSX 750 forks along with GSX 400 brake calipers for example.
One day the beast will roll out of the workshop under its own power. :grin:
If only there was more free time.
AHAMAYfrank
Re: Work in progress
#2 Post by AHAMAYfrank » Sat Dec 22, 2018 1:40 am
Smoker
#3 Post by Smoker » Sat Dec 22, 2018 3:43 am
Frame is going to look great with that bracing under the top rail.
Love the angle of the upper pipes. What tail are you using?
theredbarron
#4 Post by theredbarron » Sat Dec 22, 2018 7:16 am
Hi Smoker, the tail piece is one i picked up as a swap, it is manufactured by Harris. Next time i'm in the workshop i will get some pics. There is more bracing to be done around the headstock.
lost1750GTV
#5 Post by lost1750GTV » Sat Dec 22, 2018 8:19 am
yes, looking really good
front end sounds like a lot of work
tacky1
#6 Post by tacky1 » Sat Dec 22, 2018 10:44 am
Looking great, Its going to look class wen finished...
TwoStrokeNut
#7 Post by TwoStrokeNut » Sat Dec 22, 2018 10:46 am
Looks like a fun one!
Project bike links: NS400R - TRIPLE THREAT // RZ500 - MOSQUITO CONTROL BIKE // RZ350 - REVIVAL
'72 H1-500/'75 H1-500/'85 RZ350/'85 NS400R/'01 DR650/'07 FJR1300/'18 Tiger 1200
theredbarron
#8 Post by theredbarron » Sun Dec 23, 2018 8:39 pm
lost1750GTV wrote: Sat Dec 22, 2018 8:19 am yes, looking really good
Hi lost, the front end took a lot of time and head scratching :smt017 due to me wanting to use parts that i had in the workshop but now it's all together i am really pleased with the end result and also it becomes even more of a one off.
rd84
#9 Post by rd84 » Mon Jan 07, 2019 7:54 am
Nice work !
wolfgangh
#10 Post by wolfgangh » Mon Jan 07, 2019 9:12 am
Well done, its gonna be a nice bike!
Only proposal for improvement from my side is the front caliper bracket. I think the collars between caliper and bracket are too long, this could induce too much momentum ( force) into the bracket. I always try to mount the brackets as close to the fork mounts and calipers as possible to limit the stress on the bolts and bracket. You may want to consider a milled adapter bracket providing 2 different levels for fork and caliper?
theredbarron
#11 Post by theredbarron » Mon Jan 07, 2019 1:37 pm
Hi Wolfgang, i thought exactly the same as you, we will manufacture some different brackets when time allows. Thanks for your input.
