Carburettor help?
Posted: Sun Oct 29, 2017 9:58 am
I am in the final stages of my restoration and struggling with the carbs. I've purchased new fuel hoses where possible from Fowlers, but need some help on how everything connects up and most importantly, do I have the right hose going to the fuel tank?
See pictures below. Can anyone confirm the hose connection is set up right? Are the two long black thin hoses coiled up, just over flow pipes?
Is the formed shaped long hose ( part #47X-24311-00) the right hose connected to the other end of the "T" and does that go direct to the main fuel line to the tank?
Last question - the two yellow discoloured hoses clipped together with cable ties at the back of the cabs, are they just breather pipes? I've punched part number #90445-090G9. This is grey hose. Does it replace these two breather hoses?
Thanks for the help in advance
https://www.dropbox.com/s/z8it9c0n89tpo ... .jpeg?dl=0" onclick="window.open(this.href);return false;
https://www.dropbox.com/s/oa9opxqggerf7 ... .jpeg?dl=0" onclick="window.open(this.href);return false;
https://www.dropbox.com/s/348ciqocnwud5 ... .jpeg?dl=0" onclick="window.open(this.href);return false;
