Radiator
Jarrettvp
Radiator
#1 Post by Jarrettvp » Sat Sep 23, 2017 4:50 pm
Can anyone recommend a good way to restor my RZ500 radiator? I've stripped and cleaned it up, but once all the old paint that has flaked off is brushed off, it needs either shot blasting or something to get it in a position where I can re spray it with some heat resistant enamel paint.
Not sure shot blasting is th right thing to do, in case I damage the radiator.
Any advice?
https://www.dropbox.com/s/phvdb75iemjsx ... .jpeg?dl=0" onclick="window.open(this.href);return false;
Yamaha R6
Yamaha RZ500
pstamper
Re: Radiator
#2 Post by pstamper » Sat Sep 23, 2017 8:58 pm
I just cleaned mine thoroughly and wire brushed bad spots and used a good quality paint like POR 15 and has stayed on well. Take a pick and open all the rock damaged fins before painting.
Bengt Weil
Re: Radiator
#3 Post by Bengt Weil » Sun Sep 24, 2017 1:50 am
Did my radiator with this:
http://www.eastwood.com/ew-radiator-bla ... inish.html
Looks great with the proper finish. Expecting this paint will allow the radiator to transfer heat more effectively than normal 'hi-heat' paint products. Can't verify how it will looks after a couple thousand miles, yet...
Jarrettvp
Re: Radiator
#4 Post by Jarrettvp » Sun Sep 24, 2017 4:59 pm
Thanks very much. I'll try your advice.
Yamaha R6
Yamaha RZ500
Jarrettvp
Re: Radiator
#5 Post by Jarrettvp » Sun Oct 15, 2017 7:08 pm
Thanks for all the advice folks. Thought I would share what the finished article came out like:
https://www.dropbox.com/s/pfncf204t491e ... .jpeg?dl=0" onclick="window.open(this.href);return false;
https://www.dropbox.com/s/dwugxx8t3r7lv ... .jpeg?dl=0" onclick="window.open(this.href);return false;
https://www.dropbox.com/s/nh0fnfx2nvcij ... .jpeg?dl=0" onclick="window.open(this.href);return false;
Yamaha R6
Yamaha RZ500
Re: Radiator
#6 Post by silverstrom » Sun Oct 15, 2017 7:42 pm
Fine job. Looks perfect :smt023
1990 TDR250 Pre-Production # 000001
