Pod filters straight onto carbs
Posted: Fri Sep 08, 2017 7:03 pm
Hi all
After several years, I'm at the final stages of completing my build; just the wiring and carbs to sort out (before disassembly for painting etc)
I'm looking for info on jetting; I have jolly moto pipes and pod filters straight onto the standard carbs. Otherwise standard motor, rebuilt with new pistons and cranks. I've searched a lot through the forum to get a starting point for jetting. Filters straight onto the carbs (Mad beaver etc) is quite controversial on here! The general consensus seems to be that this set up is very difficult to jet and will never work right, especially with standard carbs. But I like the look of it and it was always part of my plan. I'm not too worried about the bike being perfectly jetted so long as it goes reasonably well, I'm prepared to make compromises; I wont be racing this bike!
The best info I have so far was in a post from MC (matt) several years ago, who had a similar set up; "I raised the pilot jet one size larger and did run up to a 380/400 main jet but I think I ended up around 290/300 rears(uppers) & 280 fronts(lowers) I would need to drop the bowls to confirm those sizes thou .."
Can anyone who has run pod filters straight onto standard carbs give me a steer. I want something to get it running so I can get some miles on it before taking it to a dyno. If it feels reasonably good I may forego the dyno. I'm at sea level.
