2-stroke oil strainer
trix
#1 Post by trix » Thu Jul 27, 2017 8:35 pm
I've modified a RC boat fuel tank (holds about 1 litre) to fit under my r6 seat to hold 2-stroke oil. I've no filter/strainer in the tank so some kind of in-line strainer would be great. Any suggestions?
Speed Freak
Re: 2-stroke oil strainer
#2 Post by Speed Freak » Fri Jul 28, 2017 4:32 am
I would add something like this into the tank:
https://assets.lowbrowcustoms.com/media ... tock-1.jpg" onclick="window.open(this.href);return false;
Inline fiters might not have enough surface with the risk of clogging.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
trix
#3 Post by trix » Fri Jul 28, 2017 8:05 pm
... Thanks spead freak, but I have already fibreglassed an outlet onto the tank so this solution would involve some reworking. I did some more searching and came across this;
http://www.ebay.co.uk/itm/MOTORCYCLE-CH ... 1069113364
this looks like it might have enough surface area?? I could check that it flows enough oil before fitting.
I also notice that the RGV/RS250 has an in-line strainer, so could use one of those if I could locate all the parts;
http://www.pjme.co.uk/cgi-bin/ss000002. ... &NOLOGIN=1
Does the standard RD500 oil tank have a strainer inside?
#4 Post by silverstrom » Sat Jul 29, 2017 12:04 am
You need to think about viscosity. That glass fuel filter would never allow enough oil to pass. You'd seize the motor very quickly.
Why do you want a strainer? If your oil system is clean and you are using oil from clean containers there is no need for an oil strainer. A strainer is just a restriction. Forget the strainer.
trix
#5 Post by trix » Sat Jul 29, 2017 7:17 am
Does the standard system have one?
tacky1
#6 Post by tacky1 » Sat Jul 29, 2017 1:45 pm
Nope, It didnt have one, I have never used one, never had any problems
trix
#7 Post by trix » Sat Jul 29, 2017 3:53 pm
OK thanks guys. Can probably get by without one then. Will just make sure tank is clean inside.
#8 Post by silverstrom » Sat Jul 29, 2017 6:20 pm
Flush the tank(s) and supply line to the pump with clean oil. After that you'll never have to worry about it.
Are you using the stock oil tanks?
trix
#9 Post by trix » Sun Jul 30, 2017 5:17 pm
No..using an RC boat fuel tank mounted under the seat.
Kalim
#10 Post by Kalim » Mon Jul 31, 2017 7:21 am
trix wrote:No..using an RC boat fuel tank mounted under the seat.
Hello, could you share more detail of your work on this alternative oil tank ?
I'm interested as I will also move the oil tank Under the seat.
David.
trix
#11 Post by trix » Mon Jul 31, 2017 7:37 pm
Hi David
I used an RC boat fuel tank bought off ebay;
http://www.ebay.co.uk/itm/Plastic-900CC ... SweW5VCTbh
The outlet wasn't in the right place so I screwed a hose barb into one end. I think it would seal ok but I fibre-glassed around it just in case. Then mounted it on a plate under the r6 seat unit I've fitted. It holds 900cc so I'll just top it up whenever I'm filling the petrol tank and it should be ok.
I hope these pictures explain it! You could probably look around for different sizes/shapes that better suit your application.
Kalim
#12 Post by Kalim » Tue Aug 01, 2017 9:11 am
trix wrote:I hope these pictures explain it!
They do !
Thanks a lot for the explanations and pictures. Very useful for my project, I'll keep that in mind ! :smt023
